i could really use some help!
Old 11-28-2008, 08:14 PM
supercharged98's Avatar
i swaped a 88 3.0 to a 93 as far as i know every thing is all set up right, such as timing, vacuum hoses, ect. the engine cranks over and every now and then it sounds like it wants to fire but nothing. i am stumped!!!!!!!!!!
Old 11-28-2008, 08:20 PM
Jewels's Avatar
did you swap from a 4 banger?
Old 11-28-2008, 08:22 PM
nope! the 93 was a 3.0
Old 11-28-2008, 08:26 PM
just a 22re's Avatar
check the coil, and fuses trust me a blowen fuse will do that dump fuel no spark then from pure compression boom
Old 11-28-2008, 08:36 PM
checked all of the fuses and every thing is good, and i am using the coil out of the running truck. the 88 was a good running truck when i bought it, the body was just rusted out to nothing.
Old 11-28-2008, 08:37 PM
Jewels's Avatar
check the feul pump fuse. and make sure the mass air flow senser is all hooked up. check for spark, if you have spark, and still can't get fuel engine, maybe get an air compressor and try to pressurize the fuel tank to help prime the system. those are my first ideas.
Old 11-28-2008, 08:50 PM
"jewls" you have my doors you theaf anyways check the afm and tps they both drive the fuel pump i say check the 3 gods
air
fuel
spark
if your missing just one then you go nowheres
Old 11-28-2008, 09:00 PM
annoyingrob's Avatar
Are you positively sure your distributor isn't a tooth off? Is it 180* off?
Old 11-29-2008, 02:54 AM
Bigblock's Avatar
Check the dist if you hAD IT OUT LOL.Also which wiring harness did you use?The are probly diff.Use the 93 of course.
Bigblock
