How to wire to running lights?
Old 10-23-2016, 05:41 AM
Zach_trun's Avatar
I bought a Lund cab visor with lights in it and I was wondering if someone could tell me the easiest way to get it wired to my running lights. Thanks
Old 10-23-2016, 09:30 AM
wyoming9's Avatar
Red face
Depends just how your going to route the wire
If your going from inside the cab up through the roof easy to make a good splice where the light switch plugs into the harness.
Going from the outside one of the front marker lights
Old 10-23-2016, 10:19 AM
RAD4Runner's Avatar
What model Escalade are we talking here?
A problem well stated is a problem almost solved.
What do you want the lights to do?
Do you want the lights to come one when you turn on your taillights?
Do you want them to turn on same time as your dome?
Do you want to be able to turn on manually even if tail lights are out?
Old 10-23-2016, 10:58 AM
wyoming9's Avatar
Red face
I think if they flash with the Hazard lights that would look Hot more so if they are PINK !!!
Old 10-23-2016, 04:39 PM
Zach_trun's Avatar
I want them to turn on with the running/parking lights... It's a 1993 ext cab 4x4 pickup sr5... I planned on running the wire through the drivers identification weather strip and down either through the firewall or the top of the fender
Old 10-24-2016, 01:10 PM
Zach_trun's Avatar
Old 10-24-2016, 01:11 PM
Zach_trun's Avatar
I meant drivers side..
