how well do you know 22re wiring?
Old 07-16-2009, 11:26 PM
*23
*23's Avatar
Exclamation how well do you know 22re wiring?
im only mildly concernd the my oil pressure guage duz'nt work, i keep oil in it.but looking at oil pressure switch..
there is no wiring attached... this is wrong, correct? the real baffler for me is there are no open electrical connections i can spot. so in short what/where is this supposed to be connected to? worth fixing? how do i describe the connector im looking for in order to get a replacement?
Old 07-17-2009, 07:18 AM
conrad's Avatar
Yes, there should be a wiring harness attached there. Mine is a black shielded wire with a gray plug. It drops down from the top side of the engine. It is easy to lose track of if you tuck it away unplugged while you are trying to do something else in there.
As far as getting a new one, I'd imagine that it is part of the main wiring harness so it might be a little tricky. I'd bet that the original one is still in there somewhere, it's just tucked somewhere you can't see it.
It would be a good time to get rid of the unreliable sender anyways and put an aftermarket pressure gauge in instead.
Old 07-17-2009, 07:41 AM
*23
*23's Avatar
does anyone know of a good aftermarket sender that uses the stock gauge?
Old 07-17-2009, 12:40 PM
iamsuperbleeder's Avatar
ummm, what exactly is wrong with the stock sendor?
maybe just a new sender, cause they can wear out, but I don't see a reason to go all out with an aftermarket setup or just sendor been there, done that, opted to just swap in an SR5 cluster with the gauge
Old 07-17-2009, 05:37 PM
conrad's Avatar
Definitely a personal preference thing... I just dislike that the gauge cluster doesn't have any numbers on it, but I'm picky about that kind of stuff.
Old 07-17-2009, 05:53 PM
*23
*23's Avatar
well the only way i would consider a aftermarket is if in fact i cant fing the electrical connection and check if it even works. upon inspection unde the hood i found a small black wire with no connector on it that stretches to within about an inch of the sender. looks to me like when the body lift was done the wire was left connected and got sperated and the p.o. removed the connector. i would just like all my guages to work
Old 07-17-2009, 06:02 PM
conrad's Avatar
I can't tell in the picture - is the plug currently on the top of the sender? It almost looks like it is. If so, the single black wire is most likely the one, especially since it has no connector.
If the case is that it got ripped off via body lift, try and get the plug off and see if you are able to reuse the plug.
Better yet - go to a junk yard and get a plug/wire and clip it off with plenty of wire to spare. Use a wire connector or solder to connect the two and you will be good to go.
Old 07-17-2009, 08:53 PM
*23
*23's Avatar
i have a 92 toy 2wd stubby with the the 22re im thinkin bout sendin to the bone yard. i think ill go hack the connector off it..........
Old 07-18-2009, 01:39 AM
abecedarian's Avatar
The sender wire comes out of the harness that is located on top of the lower intake manifold section, near the fuel injectors... around the same area the coolant temp, cold start injector time switch and temp gauge sender wiring exits. You might have to remove the upper intake to get good access to that area if you can't find the plug and / or need to splice in a pigtail to the sender.
Old 07-18-2009, 06:45 AM
Hadmatt54's Avatar
Go to the sticky that Steelydan posted that links you to a number of Toyota FSM's and download the one for 1990-1995 4Runners. If you are new to automotive wiring diagrams ( espedially Toyota) read the "How To" section first. according to the wiring diagram, your 4Runner is supposed to have a
Y/L (Yellow/Blue) wire running from the combination meter to the sender, but you said that you found a black wire???
If I were you I'd verify that the wire you assume to be for the oul sender does in fact run back to the oil gauge in the combination meter, either by a continuity check (little or zero resistance) with an ohmeter, checking from the connector at the back of the combination meter to the end of the wire or by tracing the black wire back into the harness to see if there is a jubction or a splice to the yellow/blue wire. Sometimes auto makers will use a larger gauge (size) wire or a wire with thicker insulation for sensor wires that may be subject to higher than normal mechanical stresses. There are no other wires close to the oil sender wire and it's going to take all the force of water mud, etc that gets sprayed into that side of the engine. If had sender wires on 2 Toyota trucks (22-re) break about 6 inches up in the harness. The copper strands broke yet the insulation was intact, a continuity check helped me troubleshoot this problem. Once I came across it with the first 22-re it was an easy troubleshoot the second time.
Your assumption that this wire is for the oil sender may be correct, but if it's not and you connect it you may be causing yourself a whole new batch of problems.
My 2 cents worth.
Good Luck!
Old 07-18-2009, 11:02 AM
*23
*23's Avatar
hadmat. people like you are why i joined this forum. great info. today ill see if i can use your knowledge!
Old 07-18-2009, 09:59 PM
*23
*23's Avatar
well upon closer inspections my black wire i found was infact a g/y with a black tubeand alot of oil around it..... nice call matt. no connector any where to be found but im hopeful now that i have located the wire and i know where it goes. now just making the all important connection is the problem at hand!
Old 07-18-2009, 11:30 PM
LITLRED's Avatar
My first "mod" was an oil pressure gauge and I love it. Its a mechanical gauge so both the sender and wire are now obsolete. Mine's an '86 so I'm not sure if your '93 would work the same.
Old 07-19-2009, 05:39 PM
screech's Avatar
screw it just put a mechanical gauge in its place. Did it today in my girls 86, yep its hers now- sold her lifted f150, after she snapped 3 axle studs towing a mercedes for me (customers car). painted the gauges pink.
Old 07-19-2009, 05:57 PM
oh I had the whole setup for a while:
but like I said, I ended up just ditching that for an SR5 gauge setup:
Old 07-20-2009, 07:32 PM
Blue Bowtie's Avatar
Hey superbleeder, where'd you get the guage pod?
Old 07-20-2009, 10:44 PM
*23
*23's Avatar
r u using a factory sender with your sr5 dash?
Old 07-20-2009, 11:55 PM
87AzRunner's Avatar
dude i wanna go mechanical my stock one is funky. when the key is on
it pops right up to about 3/4s but when i start the truck or the key is just
on after about 30 secs the gauge needle drops and the gauge is useless,
doesnt move one bit ill snap a pic of the wire i have for you in the mornin
of my RE
MO transplant
04-23-2023 11:58 AM
Doug4320
03-24-2018 10:11 PM
steve miller
10-10-2015 01:40 AM
1994toyota
07-17-2015 03:03 AM
bryan34w
07-06-2015 05:53 PM
Quick Reply: how well do you know 22re wiring?
