How many Sensors are on a 4runner, can you name them
How many Sensors are on a 4runner, can anyone name some
i want to know beacause ive had problems with my runner and need to know what sensors are working
thanks
thanks
umm...
throttle position sensor
air flow meter
intake air temp sensor
coolant temperature sensor
cold start time switch
distributor / hall effect
knock sensor
EGR temp
O2 (could have 1 or 2)
Neutral safety (clutch) / park / neutral
what did I miss?
air flow meter
knock sensor
EGR temp
what did I miss?
Engine Control Input Signals
Water Temp
Intake Air Temp (AFM)
Oxygen Sensor
RPM Signal (Crankshaft position)
Throttle Signal (TPS)
Vehicle Speed
A/C Switch
Battery Signal
Intake Air Volume (AFM)
Stop Light Switch
Starter Signal
Engine Knock
4WD Signal
There are obviously others for transmission (gear selector, transfer case, etc.), braking (brake fluid level), oil pressure, parking brake switch, etc.
Water Temp
Oxygen Sensor
Vehicle Speed
A/C Switch
Battery Signal
Stop Light Switch
Starter Signal
Engine Knock
4WD Signal
too many sensors what happened to the days when there was ONE or TWO sensors? where you jumped in the back of your buddys truck and went cruisin, where you checked your idle speed with the door hanging open?
1 Post
oh man the door open trick i hane not heard that one i a long time now a days you cant do that anymore tomany things to go wrong
and everyone forgot the stupid one that i only have lol the temp one ontop of the t-stat housing and yes noone ive talked to has this lol what does it do i have no idea
