How to get better fuel mileage
#41
Air's getting in there. And with no fuel thats ok, but with some fuel it would have to be progressively more as the rpms went up to prevent backfiring. Right? Anyone?
#42
1.) i'm out of gear down every hill including on the freeway. stay far away from me.
2.) edit: regarding weight, the difference in fuel economy between unweighted and having a 235lb dirtbike, all my riding gear and tools, and the 45lb carrier on the bumper of my 4runner is marginal at best... under a mile per gallon, and I have numbers to back that up if you want them. the biggest contributing factor is how far my foot is into the pedal and for how long.
2.) Speaking from a purely theoretical standpoint, acceleration is the only time the extra weight requires more energy from fuel. That energy is converted into momentum, which is then available to keep the vehicle rolling until friction and drag deplete it. That energy is wasted as soon as the brakes are applied. In practice, I have noticed a negligible difference in highway economy with my truck whether the shell is off or on...and the shell does not reduce aero drag. City economy, however, does measurably improve when I ditch the shell and 50lbs of stuff I keep in it.
Not trying to go off topic hear but "downshifting"
Ive seen a lot of people who shift thru all the gears and then shift back down thru all the gears every time they accel and decal. Downshifting is for big hills, and towing.
After all brake pads are cheap, a transmission is $$. Why double the wear on the syncros and other transmission parts to save on a 20 dollar part that takes an hour to change.
Not to mention the ease of just throwing it in neutral and using the brakes.
Back on topic, I'm sure that by downshifting your using more fuel.
Your forcing the engine to suck in more air then at idle, the ecu compensates for that extra air in all circumstance's to maintan proper air/fuel mix, as we all know.
If it didn't it would backfire every 2 seconds as your coasting at 2500rpms like a Nissan(POS).
The biggest gain in fuel economy I ever saw was ~3mpg from changing my driving habits. Beyond that, the only improvements I see are from mindfully driving only highway miles or getting a fluke tailwind.
What I would be really interested in seeing is a BSFC chart for a 22RE.
#43
dirt driver: awesome
thatguy: the rogue hello wasnt directed toward you, it was toward our neutral or even better clutch-coasting friends. i realize the idle passage, but with the ecu being minded toward cleanliness, no fuel is better than trying for a neutral burn.
to our neutral-coasting friends: i see your point, brakes are much cheaper than motors and trannys. my first job i had to drive an old mechanic around sometimes. the work truck was the first truck i ever drove on pavement with 3 pedals, and put it in neutral before i ever hit the brakes. he conditioned me not to due to the lack of control, and because the output side of the tranny is still spinning anyway
dirtdriver: whats a bsfc chart?
#44
Brake Specific Fuel Consumption is the mass of fuel that an engine uses to generate each horsepower for one hour. In metric terms, it would be measured as grams per kilowatt-hour. BSFC varies substantially over the rev and load range of an engine. Where the sweet spot is varies with design.
Honda and Subaru utility engines are provided with a single BSFC number since they are designed to run at a steady load and rpm.
#46
Not to be stuck on this word but what causes backfiring then?
In a fuel injected engine that is, obviously a malfunction of some sorts, but is it because fuel isn't being cut at coasting like its supposed to be?
Dirt driver, thats interesting, I imagine that plays more of a role in engine design then actual power output these days.
#47
Short of engine-specific info, minimum BSFC is usually around the peak torque RPM:
- http://www.land-and-sea.com/dyno-tec...using_bsfc.htm
so 2800 or a little higher on the 22RE. This jives pretty close with what I have observed with different gearing. I found better MPGs with 5.29/33 gear/tire combo that let me run about 3000-3100 @ 65. With the same tires and 4.88 gears, I am turning closer to 2800 @ 65 and get lower MPG. I think part of the difference is due to having the engine work harder w/ 4.88s and also, that is is right at the peak torque RPM and any increase in grade or headwind and it drops the RPM below 2800 and you need to down shift. With the 5.29s, you have a few hundred RPMs to work with before the torque falls off so you downshift less.
Backfiring might be due to a mis-adjusted or missing dashpot on the throttle linkage:
- http://www.4crawler.com/4x4/CheapTri....shtml#Dashpot
That device slows the throttle closing to prevent back firing when you let off the gas pedal. The ECU takes a little time to cut off the fuel, so the dash pot gives it time to adjust.
#48
2.) There again, BSFC is dependent on RPM and throttle opening. Maximum engine output does not necessarily exclude maximum efficiency.
1.) Not to be stuck on this word but what causes backfiring then?
2.) Dirt driver, thats interesting, I imagine that plays more of a role in engine design then actual power output these days.
On a side note, anyone ever use a wideband O2 sensor on an EFI car with the original ECU? It pegs full lean on decel, right? That's overrun fuel cut at work. I was paying attention today and noted when my truck stops the fuel and when it cuts back in. I let off the throttle and about a second later, after the dashpot bottoms out, I feel the engine braking increase a lot. If I don't do anything but keep slowing down, I can eventually feel the braking abruptly decrease; that's when the fuel comes back online.
2.) Output and fuel economy sell cars and, ironically, improving efficiency will improve output. As technology invariably advances, the gap between them gets smaller and smaller.
Backfiring might be doe to a mis-adjusted or missing dashpot on the throttle linkage:
#49
alright can anyone answer this.- in my 85 4runner with 4:10s and 34's 4inch lift i went from bothell to eugene 300 miles- ONE TANK in my new to me 88 p/u with 22re 33's 4:10s 4 inch lift portland to bothell about 150 it took me a about a little over 3/4 of a tank... oh and i had 233k on my 85 and the 88 has a new motor under 5000k is it not broken in completly resulting in poor fuel efficincy
#51
What size is the tank in our trucks? Well mine anyway... Its a 92 p/u. I read somewhere its a 13 gallon tank.. that seems pretty small... I use to get 22 miles to the gallon. The truck had a 22re 4:10's and a set a bald 31x10.50x15 tires. No I only get 18 miles to the gallon... same 22re engine and 4:10 but now with brand new 31 inch tires and I did a tune up. Why would it go down so much?
#54
Hi
My truck has gotten 17.95 mpg when I first got it. I have gotten 305 miles to a tank. I have to see what I am getting now. It know it does not seem to want to go 300 miles on one tank anymore. 1995 pickup 22re 5speed 192,000 miles 31x10.5-15 toyo all terains. 4.10 gears I believe.
I have noticed one thing in the time I have owned toyotas. The mpg is not hurt by reving it. I always thought it was better to lug it around but that is bad for the engine and fuel mileage. I am letting it rev more now.
My old truck which was a 1994 automatic with the same size tire 4.56 gears stock because it was automatic would get alittle less mpg in town but on the highway it would get 23mpg. There was no tachometer but I can tell you it was reving high. Plus I would bring it up to 80mph before I got to a big hill. Also that was loaded with camping gear and two bikes. With a fiberglass cap on it.
So I think that keeping the rpm around 3000 is good for mileage with a 22re. Obviously not with your foot in it. I haven't had my current truck on an all highway run yet to see the mpg.
#55
Tire size
I was just thinking what would happen to the fuel mileage if I put on the stock 235 75-15 tires. My 1994 had 225 75-15s on it when I bought it off of the original owner. They didn't stay on for long. I think it would make a big difference in town since there is more stop and go. It would be so hard to go back to little tires. I would like to go bigger to 33s but I would want to regear it at that point and then you might as well make the jump to 35s.
#57
I'd bet that it's not actually illegal. But it IS bad practice, which is why your friend failed the driving test. When you're coasting, there's not as much power to accessories - the important ones here being the power steering pump and the brake booster - as when you're not coasting. So it's not as easy to steer or brake while coasting, which could be a safety issue. It's also easier to kill the engine when you're closer to idle rpm, so you're in greater danger of losing all power. These are the reasons that driving authorities frown on it.
#58
I'll take that bet for my state since you haven't listed yours anywhere.
http://dmv.ca.gov/pubs/vctop/lov/lovd11.htm
Vehicle Code Appendix B List of Violations Division 11 Rules of the Road:
Code 21710: coasting in neutral on a downgrade.
I'm assuming that fork's location "out in the Pacific" means Hawaii. I looked and looked on their government sites and couldn't find anything about their motor vehicle code.
#60
Do NOT buy an "HHO kit." You end up burning gasoline to run the engine to drive the alternator to power the electrolytic reaction. Every time energy changes form, some is lost from inefficiency. Ultimately it takes more energy to make the electrolysis reaction happen than you can get out of it by burning the gas produced, resulting in a net loss. That, and an electrolysis device small enough to fit in a car and not overwhelm the charging system won't produce enough gas to do anything.
Also, the name "HHO" and "Brown's gas" is joke in itself. Neither hydrogen nor oxygen are monoatomic gasses(existing as a single atom), so both actually occur as pairs of atoms in the form of regular old H2 and O2, not some miracle gas called HHO.
I've also seen the argument that H2/O2 increases burn efficiency in the engine and improves economy that way. Truth is that modern engines(and by "modern" I mean less than ~50 years old) don't have nearly enough room for improvement here to break even with the energy input, let alone see a gain.
Long story short, HHO kits are a scam that costs you more, not less. Just like putting acetone in your gas.
09-04-2015 09:27 AM
Tacoma1313
08-17-2015 05:44 PM
