How do you adjust 4Runner for Colorado Elevation Driving
Old 01-30-2009, 10:07 AM
simpsons721's Avatar
Red face How do you adjust 4Runner for Colorado Elevation Driving
Hi,
I just moved to colorado and wanted to know how to modify my truck for high elevation driving (low oxygen)
if you guys know the standard procedure on what to adjust please reply
and how difficult is this to do
thanks
matt
Old 01-30-2009, 10:50 AM
Volcom's Avatar
Heavier right foot and get some momentum before the big hills
Old 01-30-2009, 11:00 AM
mt_goat's Avatar
I just go up there and drive around for a few days and the ECU self-adjusts the fuel trims. It takes a day or two to start running better.
Old 01-30-2009, 11:54 AM
T-1000's Avatar
I'm at 7,000 ft and I advanced the timing a little, it works pretty good.
Old 01-30-2009, 12:27 PM
abecedarian's Avatar
As long as the engine warms up enough for the ECU to go into closed loop mode (using the O2 sensor for mixture feedback), the ECU will adjust fuel mixture on it's own. It may take a few trips down the road, stopping and starting the engine and warming it up, before the ECU updates its trim information and fully adjusts to altitude.
You may lose some power due to the thinner air at elevation. As mentioned, a slight bump in timing might bring that back.
Otherwise, you should be good to go without any problems.
Old 01-30-2009, 12:33 PM
tc
tc's Avatar
x a bazillion
The EFI will take care of the technical stuff.
Old 01-30-2009, 01:52 PM
87LVRunner's Avatar
I added an intake to get more air moving through the engine. I also got a better exhaust, I think 2.5 inch. Those coupled with a timing advance seemed to help. I used to live in Highlands Ranch, just under 6K.
That, and just always drive downhill and you will be fine!
Moving to Vegas, my 4Runner feels like a hot rod now.
Old 01-30-2009, 02:34 PM
mt_goat's Avatar
Originally Posted by 87LVRunner
I added an intake to get more air moving through the engine.... :
So did I:
Old 01-30-2009, 02:47 PM
khany2002's Avatar
I know in the owner's manual, it gives you instructions on vacuum lines you are supposed to lengthen or shorten, to prepare the vehicle for high-elevation (above 6000 feet) driving. It says it will still run fine none the less though, if I recall correctly.
I could dig it up sometime when I get a chance.
Old 01-30-2009, 03:01 PM
87LVRunner's Avatar
Originally Posted by mt_goat
So did I:
Show off!!... That's purdy!
Old 01-30-2009, 03:06 PM
mt_goat's Avatar
Sorry, I couldn't resist.
Old 01-30-2009, 04:47 PM
DIRTCO's Avatar
I live at 9500' and there are a few things I've done to try and get more power. When it comes to adjustments the only thing you can really do is adavance your timing, I usually run between 8-10 degrees. Also, if you have ever adjusted your air flow meter you will want to return it to stock (at least until you get it tuned to your liking). Other than that the computer will do the rest.
Air is your best friend, so an intake and header / exhaust are the first things I would upgrade. Those will help to flow what air there is faster and more efficient.
Like Mountain Goat, I finally upgraded to something with more power Forced induction is really the best way to get around the whole elevation thing
Old 02-01-2009, 09:08 AM
thanks for all the advice i will go ahead and adjust my timing
JF9243176
10-08-2017 04:21 AM
truckmike26
10-26-2015 05:10 PM
Jmiller1023
23
08-06-2015 07:03 PM
TNRunner88
07-01-2015 08:00 PM
Quick Reply: How do you adjust 4Runner for Colorado Elevation Driving
