How do I remove the speed sensor from the transfer case?
Old 09-27-2015, 10:21 AM
Phantez's Avatar
I have a new transfer case for my truck and the new one didn't come with the sensor that the manual speedometer cable threads onto. Looking at the new case, the hole for it is smooth almost like it just presses in, but when trying to pry the old one out I chipped the lip on the bottom of it. How are you supposed to remove it?
Old 09-27-2015, 12:14 PM
wyoming9's Avatar
Red face
Just what pray tell are you working on
year ??
Manual Auto ??
Old 09-27-2015, 01:03 PM
scope103's Avatar
Doesn't it have a bolt to one side, parallel with the shaft?
(This picture is of an electronic sender, but I believe it mounts the same way.)
Old 09-30-2015, 08:24 AM
Phantez's Avatar
I forgot to post up. I got it out. It has that little tab with the bolt i already had out. Just had to take some pliers to it and work it loose side to side for a while before pulling it out. It's just pressed in and it was really stuck in there
Tykiller1994
08-10-2015 07:49 PM
crashburnoveride
07-10-2015 06:39 AM
wilbertd
07-06-2015 07:39 AM
karbin
07-05-2015 11:37 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: How do I remove the speed sensor from the transfer case?
