| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
highway rpm 91 22re 5sp 2wd
#2 (permalink) |
that sounds like a pretty tiny tire -- i always thought stock was something more like a 205 tire?
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts past toys: 1984 4x2 1979 4x4 1991 4x4 |
#3 (permalink) |
a 205 would be 1.10 inch taller than the 185 I am running. This is an increase of about 5%. Does this mean the rpm would be reduced by the same amount?
I tried finding a calculator for this online but no luck. Thanks |
#4 (permalink) |
assuming you have 3.42 gears(just a shot in the dark, a typical 5 speed 2wd has 3.42, 3.54 or 3.73 gears), at 70mph in 5th gear, you'd be turning a little over 2800 with 185 tires.
__________________
#5 (permalink) |
When I bought my 91, it had 195/75/14's on it. That's supposed to be the stock tire size on the base model 2wd's, while the extra cabs had the 205's mentioned above.
When I first drove it, I too though the RPM's were a bit high. I wanted to go up to 15" wheels and put on a set of 215/75/15's and it lowered the RPM's a bit. It also helped with the fuel mileage.
__________________
-RJ 1991 Toyota pickup, 2wd, 5 speed, Jeep 15x7 wheels, 215/75/15 Goodyear GS-A's, Sylvania Slilverstars, 179k miles |
#6 (permalink) | |
Quote:
__________________
http://www.trek-planner.com 1992 Toyota 4Runner|3.slow|5spd, SR5|Flowmaster 40|SAS 5" f/r|Detroit rear|ARB front|5.29's|roof rack|FLX 165|35x12.5r15 BFG MT|CB|ISR|Alarm|BentUp Sliders|C02|30 spline longs |
#7 (permalink) |
Check the label on the drivers side door jamb. It will tell you what size the truck came stock with. Could be that someone regeared the truck at some point too.
__________________
~ Joe ~ '89 4WD Pickup, Std Cab, 22RE, W56, 4.10's {REPAIRS} Head Gasket, Timing Chain Guides, Water Pump, Alternator {MODS} Flatbed, Turn/Parking Light, SR5 Cluster, SR5 Lighter, SR5 Clock, 750W Inverter {ACCESSORIES} 33x12.5 on 15x8's (no lift), Radar Detector, CB, Contico Tool Box, Pilot Driving Lights, Fiamm Freeway Blaster {WAITING} Portable Air Tank, Big 3, Hood Scoop |
#8 (permalink) |
I have the same truck but with a 4-speed.
I installed a tach in my truck, and I can tell you that going 70 miles per hour in 4th gear (1:1) on the stock 195/75 -14s has the motor spinning at about 3000 rpms. You are most likely not spinning 5 grand in 5th (0.850 OD). As for your tire, it is less wide, but I don't know if it is actually shorter in height. The tires OD is what changes your RPMs. Anyways, 22res do sound very loud. A tach is a very easy install so it's worth the added benefit. HTH, Chris
__________________
1990 Toyota Pickup 2WD [Dark Gray Metallic (179)] --Short bed/Std Cab, Amsoil panel filter + deckplate mod, diy ground kit, autometer tach, L46 4 speed/22RE, 195/75-14 Michelin LTX M/S 1984 Mazda RX-7 GSL-SE [VG Beige] --K&N Panel Filter, RB cat-back, 13" Grant GT wheel, spare tire/jack delete 1983 Mazda RX-7 [Dover White] --302 H.O./T5 swap in progress |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 85 22re 5sp efi poping out of 3rd gear! help | michalik_piotr | 84-85 Trucks & 4Runners | 14 | 04-02-2007 08:06 AM |
| 22re Highway mileage | longhungsilver | 86-95 Trucks & 4Runners | 15 | 03-30-2007 03:08 PM |
| 91 22re 2wd toyota being parted out | desert whomper | The Classifieds GraveYard | 8 | 09-25-2006 04:53 PM |
| need code help here guys....91 2wd 22re | bustah49 | 86-95 Trucks & 4Runners | 6 | 04-11-2006 07:26 PM |
