high NO reading and GETTING higher
Old Nov 19, 2007 | 10:44 AM
swaycleveland's Avatar
ive about had it ! everything i do majkes the readings go up !! wtf?
ive readed blogs for days done everything i can think of with the exception of timing
my NO reading is 1203
passing is 956
i started at a 1049 new pcv
new egr
new plugs new wires cap roter
cat and muffler are new
oil is fresh
all with 2 weeks
anyone got anything?????????????????? help
Old Nov 19, 2007 | 10:57 AM
8yota9's Avatar
Private garage $100 for a 2 year sticker..well thats what i got.
Old Nov 19, 2007 | 02:27 PM
elripster's Avatar
Something is not working. It's time to not assume that which is new is good.
First off, with numbers that high I would seriously question the cat. You can point one of those infrared thermometers (Radioshack has em but I'd try to borrow one, they are about $50) at the cat and I believe it should be around 50-100 degrees hotter on the outlet than on the inlet. If the inlet/outlet temps are the same, it is bad.
Just curious, but what do your HC's look like? Are they high but passing?
If you aren't throwing a code 71 then likely the egr is working correctly.
Bad timing, plugs, and such will raise numbers, but they should not cause a failure of that magnitude.
Frank
Old Nov 19, 2007 | 02:38 PM
frank the cat is 5 days old lol im thinkin thats not it right now im down to timing (which will e checked tomorrow) and c4
Old Nov 19, 2007 | 02:39 PM
by the way the other readings are just fine up and down a point or 2 ( which i thought might lead me in one direction or another but i cant make heads or tails of it)
Old Nov 19, 2007 | 03:06 PM
mt_goat's Avatar
Is it one of those $60 aftermarket cats? The factory cat on those early years were packed with expensive metals, I got $140 at the scrap metal recycling place for my old 93 cat. I don't see how one of those cheap cats could work as good as the original did, maybe you need to run 2 of them like the newer trucks do. I know my 2001 5VZ ECU didn't like one $60 cat at all, it threw a P0420 code about every other day. But running 2 cats is suppost to satisfy it.
Old Nov 19, 2007 | 03:08 PM
lol nope it was a factory replacement i spent all the money!
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
RatOmeter
Oct 22, 2015 03:17 PM
calderp
Jul 27, 2015 09:58 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
garagespace
Jul 9, 2015 08:37 AM
