High Idle post-headgasket (3VZE)
Old 10-31-2006, 08:00 PM
procainestart's Avatar
My friend and I recently r&r'd the headgasket on his '94 pick-up. Runs well but the idle is high, staying ~1000-1200 when warm.
Timing is spot-on, no missing vac lines that we could find. Manual says ECU sets idle, but we suspect a mechanic may have fiddled with something in the past.
Question: If we mess with the throttle (looks like there's a stopper screw) will that allow a lower idle? The only other thing I can think of is a leaky intake gasket, but it's all new stuff in there. Or maybe we screwed up a big vac line beneath the intake?
Thanks for any insight/suggestions!
Old 10-31-2006, 08:09 PM
Elton's Avatar
yes you can adjust the idle useing that flat screw try that first and let us no
Old 10-31-2006, 08:24 PM
ChickenLover's Avatar
Yep, there is an idle-adjust screw on the throttle body. That should do the trick. If it doesn't, you can try to adjust the throttle cable itself.
tomczaksdiesel
07-26-2015 10:35 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
luckypig44
07-19-2015 11:25 AM
kyletbert
07-17-2015 11:39 AM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: High Idle post-headgasket (3VZE)
