help... wheels and tires.
Old 10-08-2009, 07:58 AM
yotanation's Avatar
i have a sr5 v6 pickup and i currently have 31's on 15inch wheels.... my tires are currently low on tread and wanted to put some 17 inch tacoma wheels on it.... should i go 265-70 17 or 285-75-17 what you guys recomend.... and the tires would be bfgoodrich all terrain. thanks
Old 10-08-2009, 08:50 AM
airsoftesneeto's Avatar
to be honest i want to get some 35x12.5 A/T BFGoodrich Tires so i am biased to the larger tires. If you are gonna do heavy off roading then the bigger the better.
Elton's Avatar
unless you have a lift 285s wont work
Old 10-08-2009, 10:42 AM
skjos's Avatar
I would recommend sticking with 31x10.5xr15 because they are about $65 cheaper a piece, better acceleration, better gas milage, and no modifications required.
But bigger tires always look awesome:
A few things to check:
Is the rim back spacing close to the same? - different back spacing can cause clearance issues.
Is the rim hub diameter compatable? - toyota rims are lug centric, but you still need to have your hub fit through the rim hole.
Will your lift (you will need one) clear a 285 width tire without rubbing at full turn?
Are you willing to do some trimming to fit the larger tire?
You don't need to re-gear for 285s, but your truck will feel sluggish with larger tires.
Flying91
45
04-11-2024 04:39 PM
NCRidgeRunner
08-13-2015 04:11 AM
Luvmeye22re
08-04-2015 03:53 PM
DrZero
07-13-2015 09:59 AM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: help... wheels and tires.
