Help with torsion bars? (pics)
Old 10-17-2009, 11:48 PM
peow130's Avatar
If he was to remove the stiff downeys, then he might want to take out the AAL's, because they make the ride pretty stiff.
plus, he would probably have a raked stance lol.
i know i did when i first did my AAL's..
had to tighten my TBAR about an inch or so
Old 10-27-2009, 07:23 PM
Supra Truck's Avatar
Quick question. I just bought some downey torsion bars for a 2wd but the part# is exactly like the one in your pic. Will these fit a 2wd? Or was the guy that sold me this part wrong?
Part# 48161/48162
Old 10-28-2009, 10:32 AM
Monochrome's Avatar
Part# 48161/48162
As far as I know, the suspension is the same between our 4WD and 2WD trucks, which means they should work just fine.
Old 10-28-2009, 10:53 AM
peow130's Avatar
it's not EXACTLY the same, but the torsion bars are the same.
Old 10-28-2009, 12:13 PM
  #25
highonpottery's Avatar
since those t-bars are designed to be stiffer and carry more weight, why not just help them out with a winch/bumper combo?
Old 10-28-2009, 12:21 PM
  #26
Monochrome's Avatar
I have thought about it, but the problem is that I don't have money for a winch/bumper combo, nor would it be put to use. I don't offroad very much so it would be an unnecessary cost/feature that would make me even more of a poser than my 3" lift!
Old 10-28-2009, 12:31 PM
  #27
would savage offroad bumpers be unnecessary when they protect your vehicle in a collision? besides, you might not see a use for it now, but once you have it wouldn't you be inspired to go out and use it? i'm just trying to plant offroad seeds in your brain.
just go to a junker and get yourself some stock t-bars. swap those in and install some BJ spacers so you don't have too much of a rake from the AALs in the rear. i wouldn't ditch the AAL unless you never ever haul anything - but that defeats the purpose of a truck doesn't it?
like said before, get yourself some new shocks. they will greatly improve your ride no matter what. at 270k, you've gotta be in need of new shocks, especially if they're the originals.
Old 10-28-2009, 01:07 PM
  #28
TubedYota's Avatar
Tell me if you decide to get rid of the t-bars and extra leaves. My stockers don't like my snowplow.....
Old 10-28-2009, 01:23 PM
  #29
Monochrome's Avatar
Yeah, this is good advice. I think I'll eventually go the stock t-bar w/ bj spacer route. Then we'll see if the AAL needs to go. Shocks are a good idea too, I don't know if they've ever been replaced. But doing all of this is a LOT of work, so I think I'll put it off a bit longer...
Old 10-28-2009, 01:38 PM
  #30
it's not that much work. the hardest part is probably deciding what you want to do. if it were me, i'd just keep the t-bars but loosen them up for a tad softer ride, install some BJ spacers up front while you're at it, install new shocks + steering stabilizer, rebuild your idler arm, get a lifetime alignment, and then go hit up some of that great NW wilderness.
Old 10-28-2009, 01:45 PM
  #31
Monochrome's Avatar
Good recommendations, but look at the first page of this thread and you'll see that I can't loosen up the t-bars anymore -- I'm already at the end of the adjuster bolt. And it is a fair amount of work for me because I'm inexperienced with working on my car. Everything that takes someone 1 hour takes me at least 2 hours. And redoing the suspension would probably take me a full weekend (which I don't have right now), though it would be really good experience.
And X2 on hitting up the wilderness here. Mountains are starting to get snow.
Old 10-28-2009, 02:29 PM
  #32
WAIT! no one answered my question.
Based on the Sway A Way website the 2wd bars should be 36" and 4wd 42".
Old 10-28-2009, 03:08 PM
  #33
akaphilly's Avatar
that means they are differnt.
monochrome. thoes nuts are over 1 inch long. do me a favor and stick something down the nut and measure how far away the bolt is. i'll get you an exact measurement of the bolt later.
Old 12-05-2011, 07:41 AM
  #34
87Roxanne's Avatar
monochrome, i know its been years...but it would be nice to know some changes/results made.
andrewtexas123
07-06-2016 01:49 AM
89fourrunner
02-17-2016 06:52 AM
Steven.m.paulk
08-16-2015 04:52 AM
mavenator
08-13-2015 01:12 AM
coffey50
07-28-2015 10:55 AM
Quick Reply: Help with torsion bars? (pics)
