Help!! part number for 3vz-E camshaft oil seal
Old 05-15-2009, 08:29 PM
93toyrunner's Avatar
Hi I have been battling leaking valve cover gaskets for a year now I know about rtv in the corners to hold but my problem is the big cam shaft caps on the back side of the engine. I went to toyota and they can not find a part number I need the gasket for the cap not the big plug on the back side but on top. I f anyone can help I would highly appreciate it Thank You
Old 05-15-2009, 09:15 PM
Justinlhc's Avatar
I could be wrong, but I don't believe there is a gasket there. It calls for sealant there, not a gasket. That's how mine was. You're talking about the rear bearing cap, right?
Old 05-16-2009, 06:47 AM
Yes the rear bearing caps, I was going to just use rtv seen as I can not find the gasket or o ring that is what I will use thanks for the help though cause it reassures my rtv idea
Old 05-16-2009, 08:44 AM
bugs1961's Avatar
RTV is correct. The FSM shows where to put it, but it's basically in the grooves on the cap.
Old 05-16-2009, 10:06 AM
Thanks I will have to try that
bigjstang
08-25-2021 12:41 AM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
HRDC0R19
07-05-2015 06:43 PM
ptb12
07-05-2015 01:49 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Help!! part number for 3vz-E camshaft oil seal
