Help Needed to pass smog!!!!!!!!!!!
Old Sep 8, 2008 | 04:16 PM
86Crawler's Avatar
Exclamation Help Needed to pass smog!!!!!!!!!!!
Hi I have a 1986 Toyota 4X4 with a 22re, 5 speed. I need to pass smog but I have a code 11 and 12 on my car and need help diagnosing it.
Code 11-Throttle switch (IDL) point in the throttle position Sensor (TPS) is OFF during diagnostic check- defective TPS circuit, TPS or ECU.
Is the circuit build onto the TPS because my book only shows how to check carbureted only. Also how would u check the TPS.
Code 12- Knock Control sensor signal has not reached judgement level in succession- defective knock control sensor circuit, knock control sensor or ECU.
Dont exactly know location for this or how to fix it.
Any help will be greatly appreciated
thanks
bigjstang
Jun 2, 2025 03:56 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
coryc85
Jul 7, 2015 04:05 AM
Jnkml
Jul 6, 2015 01:20 PM
mickyd9990
Jul 6, 2015 09:01 AM
