Help HOW do you plug the Transmission during Drive Shaft Removal
Old Aug 8, 2008 | 03:10 PM
simpsons721's Avatar
Red face Help HOW do you plug the Transmission during Drive Shaft Removal
Hi
How do i plug the transmission when i pull out my drive shaft from the transmission i have 2wd
I would like a tip like something homemade will work or by just lifting the rear will that work
thanks
Old Aug 8, 2008 | 03:13 PM
cubuff4runner's Avatar
Originally Posted by simpsons721
Hi
thanks
The driveshaft bolts onto a flange. There shouldn't be any plugging involved.
Old Aug 8, 2008 | 03:15 PM
yes it does but on the other side (not the bolted one) maybe 2wd it slides in the trans at the sleeve yolk
pg. PR-7 in the fsm and they use a special plug for the trans
Old Aug 8, 2008 | 03:16 PM
904_runner's Avatar
I don't think it is the same for autos. At least it wasn't with my moms 99 2wd.
When i had to pull her driveshaft to replace a u-joint. I simply parked with the truck on a slight incline, and didn't leak a drop.
Old Aug 8, 2008 | 03:17 PM
cool ya when i was researching the removal i swear someone said just jack up the rear but im just trying to make sure before it goes down
Old Aug 8, 2008 | 03:20 PM
904_runner's Avatar
I didn't have a problem with it, but im sure if it was dripping it would be fine to shove a rag in the hole( just be careful to not loose it in there if thats possible lol.)
Maybe now would be a good time to change the tranny fluid?
Old Aug 8, 2008 | 03:28 PM
idanity's Avatar
yeah like above, its part of the fluid change,
really, if its leaking, it may be a seal issue
voiddweller
19
May 2, 2016 09:10 PM
94whiterunner
Sep 22, 2015 07:25 PM
bigblue82
10
Jul 6, 2015 08:27 AM
TNRunner88
Jul 1, 2015 08:00 PM
Gamble_STi
Jul 1, 2015 12:51 PM
