Help With Homework
Old Sep 11, 2008 | 04:35 PM
jason191918's Avatar
3VZ-E vs 22R-E (Behind the Numbers)
I was hoping some wise toyotian could help me out.
1. How much does the 3vze and the 22re weigh?
2. What is their fuel consumption (lbs/hphr or kg/kWhr)
I know this is probably a stretch, but I figured asking would hurt.
See Post #15
Old Sep 11, 2008 | 04:52 PM
abecedarian's Avatar
1)- alot
2)- too much
sorry, I can't help you...
but I want to ask:
by fuel consumption, are referring to brake specific fuel consumption?
Old Sep 11, 2008 | 05:07 PM
Originally Posted by abecedarian
1)- alot
2)- too much
but I want to ask:
"specific fuel consumption"-yes (he did not specify if it is brake or not, so whatever I find will work).
After some research I found the 22re is about 340lbs, 400lbs, or 315lbs. I found the 340 and 400 on one site each, and the 315 on several sites.
The 3vze I found to be 360lbs, 325lbs, or 350lbs (once each).
Thanks for the reply.
Old Sep 11, 2008 | 05:45 PM
Georgiadave's Avatar
I think you are being asked to compute pounds of fuel per horsepower hour, or per kilowatt hour. I would do it on horsepower, because you can get engine performance data in horsepower. Things you need to know:
1. Horsepower at RPM. ( Usually a horsepower/RPM curve for your engine will give you this data)
2. Since this is per hour, the easy way to do the calculations is to use RPM at 60 MPH.
3. Your milage at 60 MPH, using your highway mileage is probably close enough.
4. The weight of a gallon of gas
An example-
2800 RPM at 60 miles an hour
Horsepower at 2800 = 120
Mileage 18 MPG
Weight of 1 gallon of gas = about 6 pounds
6 pounds per gallon*(60 miles in one hour/18 mpg = 4.1 gallons per hour) = (24.6 pounds per hour at 120 horsepower 24.6/120 = .205 pounds of fuel per horsepower hour.
To do the problem in watts, convert horsepower to watts.
A calculation of this type is somewhat theoretical, as while speed is a direct function of engine RPM, fuel consumption is a function of RPM and load. If you are driving uphill, your fuel consumption to maintain RPM/speed will be higher than if you were going downhill.
I hope this helps.
Old Sep 11, 2008 | 05:55 PM
2. Since this is per hour, the easy way to do the calculations is to use RPM at 60 miles per hour.
An example-
Mileage 18 MPG
I hope this helps.
Thanks for the help. I need it in both units, but I know how to convert it.
Old Sep 11, 2008 | 07:51 PM
aviator's Avatar
Very interesting... why are we calculating this?
Old Sep 11, 2008 | 08:22 PM
Because my teacher told me too.
I was told to calculate power, torque, BMEP, max/operating speed, mean piston speed, fuel consumption, efficiency, and specific power for 2 engines.
I chose the 3vze and the 22re.
Old Sep 11, 2008 | 08:33 PM
91Toyota's Avatar
I think the block is about 60-70lbs or so. I can pick it up and put it in a car. Not sure about fuel consumption. Hope that helps!
Old Sep 12, 2008 | 05:32 PM
mr toytech's Avatar
i would like see the results of this. could you post them?
Old Sep 12, 2008 | 08:56 PM
aviator's Avatar
I am also curious to see the results... it would be nice to know the baselines of our engines...
Old Sep 12, 2008 | 09:35 PM
I do not have the results done yet, but I will post them. Beware-they are going to be somewhat rough...
Old Sep 13, 2008 | 11:14 AM
http://www.kandn.com/dynocharts/57-9006_dyno.pdf
wow, only 68hp at 3000rpm...
Old Sep 13, 2008 | 11:24 AM
Atomic's Avatar
...Go Cubs! (Referring to your avatar)
Old Sep 13, 2008 | 11:30 AM
cubssuckclub.com
Old Sep 13, 2008 | 05:45 PM
I find it interesting how the 3.0 has a better BMEP, specific power, and efficiency...maybe it isn't all bad?
Note-I made a few assumptions.
3vz-e weight=360lbs; 17.5mpg at 60mph at 68hp at 3000rpm
22r-e weight=315lbs; 24mpg at 60mph at 62hp at 3000rpm
Questions, Comments?
Old Sep 13, 2008 | 06:01 PM
looks like you almost nailed it on the head.
the v6 offers more power
all it seems it doesn't offer is better MTBF.
Old Sep 13, 2008 | 06:04 PM
and fuel efficiency...
Old Sep 13, 2008 | 08:13 PM
91Toyota's Avatar
YES! I thought I only had 115hp.
Stupid question.
Brother has an 86 crx. 90hp/90ft lbs. 2k lbs.
My truck. '91. 115hp/140ft lbs. 2400 lbs.
Who would likely win? Has nothing to do with this thread...but I really want to know...lol. I plan on racing him after I rebuild my engine...lol
Old Sep 14, 2008 | 07:31 AM
aviator's Avatar
Very interesting Jason...
looks like the overall efficiency of the 3.0 is higher at the expense of increased fuel consumption...
another interesting note it seems that based on peak torque point half the available horses are doing all the work... so what are the rest there for? show? lol
wake2wake623
3.4 Swaps
Sep 21, 2009 08:12 PM
rlhd00z
10
Feb 21, 2009 07:22 PM
rlhd00z
3.4 Swaps
24
Feb 16, 2009 12:22 PM
Fink
Sep 29, 2005 06:01 PM
