HELP!!! Clutch or trans Problem????!!
Old 02-08-2009, 07:48 AM
B-_-RAD's Avatar
To make a long story short last night I was about 2 inches shy of the door handles being in water when my clutch just stopped gripping and I was "stuck", and my truck is on 36's. For some reason it apperars that there is gear oil leaking from the slave cylinder, and when I got pulled out of the hole last night with the clutch in it would not go into gear. Now it will go into gear but the truck wont move. When I bought the truck 1 month ago the "mechanic" who lives up the street from me had already replaced the clutch. For some reason I think that the gear oil is now all over the clutch causing it to slip, How could this happen? any other Ideas on what it might be?
Old 02-08-2009, 12:18 PM
B-_-RAD's Avatar
Update no gear oil on clutch disk.. just ordered the 2100 psi marlin crawler clutch and am going to buy a new flywheel. I think the 'ol dodo autozone clutch ate it... even with the slave cylinder removed and starting the truck in gear it barely moves.. Any thoughts?
Eggslinger
06-08-2019 03:32 PM
keithporter83
07-24-2015 07:37 AM
the1998sr5
07-16-2015 06:20 AM
Poncho0206
07-10-2015 06:21 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: HELP!!! Clutch or trans Problem????!!
