HELP ! Check engine light!
Old 04-28-2009, 06:48 AM
dcmbsc's Avatar
94 toyota pickup 4x4 , I just tried driving to school 10 min ago and the check engine light came on. Soon as i tried getting up to speed on the hwy , the truck had almost no trottle response and almost tried cuttting off, I went very slow right back to the house.....help please
Old 04-28-2009, 07:12 AM
dcmbsc's Avatar
ttt...
Old 04-28-2009, 07:15 AM
4Crawler's Avatar
Pull the stored code and see what that tells you:
- http://www.4crawler.com/4x4/CheapTri...CheckConnector
Hint: The link above tells you how to do that...
Old 04-28-2009, 07:21 AM
dcmbsc's Avatar
how do i find out the code?
Old 04-28-2009, 07:22 AM
Junkers88's Avatar
Click on the link that 4crawler posted and follow the instructions.........
Old 04-28-2009, 07:28 AM
dcmbsc's Avatar
dont really understand it. I thought it was easy as pluging in a computer or something.
Old 04-28-2009, 07:32 AM
4Crawler's Avatar
The computer is already in the vehicle, you stick in the "scan tool":
And read the flashes on the CEL:
http://www.off-road.com/toyota/tech/codes/index.html
Old 04-28-2009, 08:04 AM
dcmbsc's Avatar
Thanks guys, I came up with got it working and I counted i think , the code 52 which is ...
52
KNOCK SENSOR SIGNAL--OPEN OR SHORT IN KNOCK SENSOR SIGNAL
--KNOCK SENSOR/CIRCUIT
ECU
Old 04-28-2009, 08:24 AM
dcmbsc's Avatar
where is the kock sensor on the motor?
Old 04-28-2009, 10:13 AM
GSGALLANT's Avatar
The knock sensor is between the heads. You have to pull the air intake chamber and the intake manifold to get to the knock sensor. If you're going to do that, then replace the knock sensor wire while you're in there. They get brittle over time.
If you search hard enough on here, you'll find links to a copy of the service manual for your truck (like this one). If you search even harder, you'll find the link to the actual section you need to get everything out of your way to get to the knock sensor (like this one). Your questions have all been answered on here many times.
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
Kalihi,HI
07-09-2015 04:29 PM
God's Bounty Hunter
07-08-2015 12:54 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: HELP ! Check engine light!
