HELP 22re truck wont stay running
#41
Sound like you guys have the same problem as i do right now.... so i check my AFM bought a new AFM (wasnt cheap)... now i did a full tune up cap rotor wires air filter fuel filter spark plug ect.. still wouldnt run but for a few sec. then i replace my relay still didnt work and i also check my vacume lines everthing look good, they where all not crack or miss all there in there right place... also check my air intake to make sure i didnt have any hair line crack there wasnt any cracks at all.... now that saying some where in the line for my toyota i have a fat wiring problem that im still looking into... so no my toyota as of right now not running i have a 91 toyota pickup 22re 5 speed. i can not figure it out.. but to help you try moving around your EFI relay fuse might be loss on you that what i had to do to make my toyota run fine (Back in the day) This is my 6th toyota i owned and also frist time i have problem like this... ill let you know what i find out in the end...
DacodaYota
09-02-2015 02:13 PM
