HELP 22re truck wont stay running
Old 07-12-2009, 10:26 AM
PlugItIn's Avatar
ugh...i should of known this...same thing happened to my truck. Sorry for not thinking of it earlier =( Good luck with it though!
Old 07-12-2009, 10:29 AM
clappedoutyota's Avatar
how did u fix it bud? did u just put a rubber piece in there and clamp it on ??? lemme know, thanks i appreciate it... I should be pissed, but this truck is so easy to work on its not even funny lol. im used to 1000hp drag car motors where every little change u make effects something else, so this is all very simplistic, its fun haha
Old 07-12-2009, 10:37 AM
PlugItIn's Avatar
The PO had that bend piece break off from the pump unit itself...so he JB welded a hard line in there and hooked it up to a rubber hose. Worked good cause there was no bed on the truck. As soon as i put a bed on it, it broke the JB welded peice because it was too high. I cheated and have a couple junk toys and already had another tank out, and i just swapped em. If you can fit a rubber line in there, that should work.
Old 07-12-2009, 10:39 AM
ya, im thinking thats what im gonna do, i really dont wanna get a whole new hard line, no so much cuz of price cuz id bed it myself, but holy jesus what a pita that would be to snake through there lol
Old 07-12-2009, 10:44 AM
  #25
PlugItIn's Avatar
yeah, i cheated too cause i just pulled off my bed and did it all from the top =)
Old 07-12-2009, 10:56 AM
  #26
ya, its real easy to get to due to the hatch right there, good engineering in that respect on toyotas part
Old 07-13-2009, 05:38 PM
  #27
is there anything else i should be looking into ? besides fuel pump <?
Old 07-13-2009, 05:40 PM
  #28
PlugItIn's Avatar
did fixing the hose not fix it?
Old 07-13-2009, 06:00 PM
  #29
i havent tried fixing the hose yet, i was just asking if anyone else had any ideas, i work 300miles away during the week, by st. louis on an oil refinery, then come home and tinker o the weekend, good news is, im taking thurs and friday off so i can get to the bottom of this jalopy lol
Old 07-13-2009, 06:10 PM
  #30
toyota4x4907's Avatar
AFM. I had the same problem with my '88 when I first bought it. The plug on the AFM was loose and dirty. check around there.
Old 07-14-2009, 05:29 PM
  #31
hrmm ill check that as well
Old 07-14-2009, 06:04 PM
  #32
Lumpy's Avatar
Make sure the lil flapper thingy moves real easy like and not sticking anywhere. I think once you get the fuel line fixed you'll be good to go.
Old 08-17-2009, 12:19 PM
  #33
well im back, fixed the line, and put a new pump and filter in, does the same damn thing, anyone else have any ideas
Old 08-17-2009, 02:32 PM
  #34
could this be a air flow meter problem? no cracks in the intake track that i can see
Old 08-17-2009, 02:39 PM
  #35
4Crawler's Avatar
Test is and find out:
- http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml
Old 08-17-2009, 03:24 PM
  #36
my house is 77 degrees, and im getting 1900ohms for the e2-tha reading otherwise its looking like its all in spec, when i push the flapper in, i get about 80ohms with the flapper all the way ope
Old 08-17-2009, 03:27 PM
  #37
im at a total loss now, i got no idea what the hell is making this thing not work? its obviously not fuel now
Old 08-25-2009, 06:50 PM
  #38
anyone else got any ideas? anyone in the northern illinois area with knowledge of these things ? HELP hunting seasons coming and i need my buggy!
Old 08-26-2009, 10:27 AM
  #39
jungle_runner's Avatar
sorry if this is repetitive, i haven't read the whole thread, but:
TPS, AFM, O2 Sensor, Vacuum Leak, Fuel Pressure, Timing, and check your diagnostic codes.
Old 03-10-2011, 06:45 AM
  #40
Jmitchell5's Avatar
Did you ever figure out what the problem was? I have an 85 toy extra cab with the 22re and its doing the same thing I've only had the truck for a week and it only ran fine the day I bought it...not sure where to start
Quick Reply: HELP 22re truck wont stay running
