Help!!
Old Jul 2, 2008 | 02:56 PM
mikilu88's Avatar
Help!!
I installed the pro comp es2000 stabilizer on my 1989 toyota 4runner. It is stock height but it has 31x10.5 r15 tires. I can turn all the way to the right but when i try to turn to the left i can't turn as much. Any ideas why this is? Any suggestions on how to fix it?
Old Jul 2, 2008 | 03:03 PM
TOYOTA 1's Avatar
is there any adjustment where the shock bolts to?
i should know that answer but Ive never replaced that shock! i sas'ed before i needed to.
Old Jul 2, 2008 | 03:07 PM
Jay351's Avatar
I the shock binding? How far can you turn it? Are we talkin only a little, or almost to full lock?
Old Jul 2, 2008 | 03:12 PM
mikilu88's Avatar
turning is
the shock doesnt bend, i can (if i try hard enough) push it all the way down and then take it all the way out. When i turn to the left it fully locks
Old Jul 2, 2008 | 03:19 PM
Jay351's Avatar
Im a little confused about the problem then....
Old Jul 2, 2008 | 03:21 PM
mikilu88's Avatar
hahaha
that makes two of us... Is there something i need to adjust? or it just bolts on? I asked the 4wheelparts people and they said i didn't need anything else for the install. But i did not ask if i needed to adjust it or align it in some way?
Old Jul 2, 2008 | 03:43 PM
Jay351's Avatar
Sorry, I ment I was confused about what the problem is. Perhaps some pictures would help..
Old Jul 2, 2008 | 04:43 PM
Snotrocket's Avatar
Are you sure you've got the right stabilizer.
I replaced mine and can't for the life of me think what your problem could be.
Old Jul 2, 2008 | 09:23 PM
just a 22re's Avatar
did you install the shock with the tyres at full lock like you should have?
i get whats wrong with your rig my friend
left \ - \
right / -- /
as in the shock up front!!!!!
Old Jul 3, 2008 | 06:04 AM
nmtoy's Avatar
That happened on my 90 when I got one from FWP. I was sold the wrong one... Take it back and make them get you the correct one!
Robb
Old Jul 3, 2008 | 07:38 AM
Brenjen's Avatar
Yep I'd have to agree with nmtoy; you got the wrong one. It doesn't matter how the wheels are aligned when you replace the stabilizer, it's a simple put it on type part. If it isn't allowing full range of steering it's got to be the wrong part # - unless you unbolted something else in the steering linkage & moved tires or steering wheel etc. If all you did was unbolt the old stabilizer & bolt on the new one it's the wrong part.
Old Jul 3, 2008 | 08:40 PM
oh i though new stabilizers came with new mounts sorry
