Head Gasket gone, how much longer can I drive
Old 01-14-2006, 01:33 AM
Azi
Azi's Avatar
My mechanic said that my 88 4runners 22RE's headgasket needs to be replaced. I dont have the funding for it right now and still need to drive to work, is it safe to drive it? Or should I fix it asap? Any help appreciated.
Sorry if this is a very basic question, Im new to this.
Thanks
Old 01-14-2006, 04:43 AM
powerwagon67's Avatar
Fix it ASAP!
Old 01-14-2006, 11:08 AM
Azi
Azi's Avatar
Ok, what will happen if I keep it running? Right now the engine light comes on and sometimes it shuts down when changing gears.
Old 01-14-2006, 12:08 PM
trythis's Avatar
if water gets into your cylinder and the cylinder compresses the water has to do somewhere. If it doesnt squirt out the head gasket hole, it will not compress, ruining the valves. Water is not a lubricant, it will get into things that need oil, they will get hot, build up friction and stop moving, your engine bearings could lock.
thats one of those things that you ought to fix.
Old 01-14-2006, 12:09 PM
Caffeine's Avatar
You'll get oil in your coolent, and coolent in your oil. So basically your isn't as oily, and your coolent isn't so cool. Eventually you'll screw up your engine, and start warping the block. At which point you might as well cut your losses and buy a new 4runner. If it's left for a little bit you'll need a new short block, but if you leave it long enough and you'll need a new long block.
Old 01-14-2006, 12:22 PM
vmax84's Avatar
Easy fix...............dump a can of "stop leak" in your anti-freeze and drive it. Easy and cheap fix.
vmax84
Seriously...........quit driving it and get it fixed.
Old 01-14-2006, 04:29 PM
Azi
Azi's Avatar
Thanks for the better understanding of the headgasket, appreciate it.
Old 01-14-2006, 04:42 PM
miket223's Avatar
I would say you're probably safe to drive it 50 feet to get it into your garage to fix it. Any driving with a blown biscuit only damages the engine.
bigjstang
08-25-2021 12:41 AM
Colington
03-08-2020 09:51 AM
Road Bull
10-10-2015 04:55 PM
smiley52
07-11-2015 05:16 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: Head Gasket gone, how much longer can I drive
