Having trouble locating pressure regulator
Old 04-07-2008, 07:39 AM
iam_turner's Avatar
I'm feeling a little noobish today,
I was reading some forms where people have had their rigs (with 3vze) catch a fire due to a bolt within the fuel pressure regulator. I wanted to check mine out to ensure the same thing does not happen to my runner (with the 3.0).
Does anyone have a pic of what/where the pressure regulator is located - I have checked along the fuel rail where the injectors are...I've probably looked right at it, but am not sure.
Thanks.
Old 04-07-2008, 07:48 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
You're referring to the fuel dampener, I do believe. The regulator has no bolt within it. It does have a threaded "shaft" for the lower portion of the body with a lock nut. The shaft threads down into the fuel rail and the nut locks it down.....and there's the fuel line that goes to it, so it could leak from either of those points and cause fire. Regardless, the typical problem people have is with the dampener.......located on the firewall end of the passenger side fuel rail.
Thoughtfully illustrated by our friends of Toyota engineering here:
http://personal.utulsa.edu/~nathan-b...68cylinder.pdf
Doug4320
03-24-2018 10:11 PM
justdifferentials
Just Differentials
09-17-2015 06:14 PM
jjrbus
07-27-2015 11:06 PM
Poppie51
07-23-2015 05:03 PM
Poppie51
07-16-2015 06:16 PM
Quick Reply: Having trouble locating pressure regulator
