Having Trouble - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-05-2009, 03:04 PM   #1 (permalink)
Having Trouble
So recently my 87' 4runner has been acting strange at first i thought it was electrical so i replace the cap rotor plugs and wires but that didnt fix it. So heres the symptoms at low rpms it sputters and kinda cuts out unless i stomp on the gas then once it gets to 2500 or so (guessing since i have no tach) it stops. any ideas whats going on?
bearfoot990 is offline
Old 01-05-2009, 03:30 PM   #2 (permalink)
Windsor's Avatar
EFI? check for vacuum leak.
__________________
'87 T4R Deluxe, mall crawler
every non-SR5 option installed (sans AT), as well as:
* Cruise Control (dealer installed)
* Michelin LTX A/T2 31s on 1st-gen alloy rims
* SmittyBilt granny step bar
* SR5 Instrument Cluster
Windsor is offline
Old 01-05-2009, 03:39 PM   #3 (permalink)
Spence1016's Avatar
Send a message via AIM to Spence1016
that sounds more like a fuel delivery problem than electrical. Try checking/replacing fuel filter, fuel pump, injectors. Has it been sitting for a long time?
__________________
2000 4Runner Limited V6 Auto... 2wd =[[[
Sony GT510 head unit, Kenwood 1700 watt max mono amp, Two 12 inch Polk Subs in ported box, 3 farad capacitor, neons in front footwells
Foglights on bottom of rear bumper
Optima Yellowtop, Kc daylighters on front bumper
Vortex muffler and Trueflow airfilter
Spence1016 is offline
Old 01-05-2009, 03:46 PM   #4 (permalink)
No
its my daily driver, it sat for about 3 days over the holidays but thats it. and yeah 22re EFI. yeah thats kinda what ive been thinking is fuel delivery or a vacuum somewhere the question is... where?
Old 01-05-2009, 03:51 PM   #5 (permalink)
bigt's Avatar
or afm.. causing fuel pump.. or ignitor/coil
any hard starting when cold?
__________________
1991 HILUX SURF SSR-X turbo diesel right hand drive toyota imported in 2005 from japan,
130,000 km 31 bfg a/t auto
current build
1987 LWB suzuki samurai. turning 2 into one.. yota axles welded front to back, yota springs , ifs steering box,, this bad boy will not only eat jeeps but toyotas aswell \m/
bigt is offline
Old 01-05-2009, 03:54 PM   #6 (permalink)
Nope it starts just fine just runs funky.
Old 01-05-2009, 03:56 PM   #7 (permalink)
oh it idles at a really low rpm as well
Old 01-05-2009, 04:20 PM   #8 (permalink)
Windsor's Avatar
Generally fuel delivery problems get worse at higher RPMs.
Vacuum leaks, OTOH, really show during low RPMs because the leak could equal the amount of air passing your AFM. Also, most ECUs built around this time use pre-built maps for idle and WOT, so the O2 sensor is out of play. At higher RPMs, most of your air is coming through the AFM and the closed-loop mode of the ECU can compensate for the minor offset.
First off do a visual check of everything after the AFM. Get a flashlight and mirror and look on the bottomside of the piping and vacuum tubing. The obvious places to look are at joints and bends.
If you find something, you can verify with a tiny shot of WD/40 or starter fluid while idling -- if the idle improves, you found it.
If you can't find anything, then do the WD/40 or starter fluid test anyway, picking key locations again (especially blind spots that you couldn't get a mirror into).
__________________
Windsor is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
GM is in trouble Paul H. Off Topic Talk 25 11-23-2005 06:10 PM
SAW Trouble, HELP. Stump1883 95.5-2004 Tacomas & 96-2002 4Runners 3 09-14-2005 08:07 PM
Am I in trouble? Ironmike4x4 Off Topic Talk 18 05-09-2005 10:54 AM
Trouble. Reading Trouble Codes evilcow 95.5-2004 Tacomas & 96-2002 4Runners 3 10-02-2004 08:05 PM
Help! In trouble with the Po! nolongeraneqaddict 95.5-2004 Tacomas & 96-2002 4Runners 1 10-23-2003 05:25 PM
2009 InternetBrands, Inc.
