YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-17-2008, 09:07 PM   #1 (permalink)
94toy4x4fever's Avatar
Have code 71! yeah I know its the EGR
I know that code 71 is something to do with the EGR! So were do you guys think is the best palces to start trying to find out what the problem is!
__________________
94 toyota pickup. Work in progress!
22re w/ RV cam
pacesetter header
K&N cold air
31" cooper stt's
Want to do: SAS, Lift, 35" tires change gears, V6 swap
94toy4x4fever is offline
Sponsored Links
To remove this ad, register today!
Old 05-17-2008, 09:16 PM   #2 (permalink)
904_runner's Avatar
Start by seeing if the egr valve is working. You can pull off a vacuum line and replace it with the one at the top of the egr and see if it will open.
__________________
-Mike
1990 4runner SR5, 3.0 with 250K, 5-speed, 4.56 gears, warn premium hubs, Hella 500's, Rancho 9000's, 33X12.50's crappy dunlop tires, rear lock right, 4" trailmaster lift with lc coils in rear
Soon to come: New wheels and tires, Sliders, CB.
One Day: 3.4 swap!
904_runner is offline
Old 05-17-2008, 09:42 PM   #3 (permalink)
well I tryed that, I pulled a vaccum line off of the intake. Thats right, right! Pull a line off that has suckion right? I did do that and it did not stall out/ sputter. Does that mean I need a new EGR valve? I know all my vaccum lines are hooked up right! I went over the diagram a few times! I just want to make 100% sure it is the EGR valve before I go and spend like 180 bones on it!
__________________
22re w/ RV cam
pacesetter header
K&N cold air
31" cooper stt's
Old 05-17-2008, 09:42 PM   #4 (permalink)
ozziesironmanoffroad's Avatar
Send a message via AIM to ozziesironmanoffroad
a neighbor mechanic told me today if its throwing a EGR code, and its not fixed, the computer will screw with the mixture and fry the fuel injectors and clog up the cat. converter... i doubt this is true, but maybe you might want to look into it... i sure am...
__________________
1988 Toyota P/U 4x4
22RE 258,000 miles on original motor
pioneer CD deck
31x10.50x15 BFG A/T
BAJA 100W lights on prerunner bumper
KC Daylighters 100W
rancho rs5000
MUD IS A VALID PAINT JOB!
If not living life to the fullest, why live it?
you just hung a vacancy sign on your ass, and my foot's looking for a room
my trucks official buildup thread
ozziesironmanoffroad is offline
Old 05-17-2008, 09:44 PM   #5 (permalink)
yeah got ya! I dont have a cat on the truck (yeah i know there will be some guys give me crap for that) and also the truck is running rich! Im going to buy new injectors soon!
__________________
22re w/ RV cam
pacesetter header
K&N cold air
31" cooper stt's
Old 05-17-2008, 09:58 PM   #6 (permalink)
904_runner's Avatar
Sounds like the EGR is bad.
__________________
-Mike
One Day: 3.4 swap!
Old 05-17-2008, 11:02 PM   #7 (permalink)
Anyone else have any ideas? Thanks to everyone that has helped
__________________
22re w/ RV cam
pacesetter header
K&N cold air
31" cooper stt's
Old 05-18-2008, 01:24 AM   #8 (permalink)
If it does not stumble/stall when vacuum is applied (Use your mouth!) to the EGR valve, then it's NOT functioning. This is the same test that's required for smog check (except the techs have nifty MityMite pumps).
Non-functioning EGR valves can be caused several things, with "clogged passages" being high on the list. Running "rich", huh?
anotherjeff is offline
Old 05-18-2008, 02:13 PM   #9 (permalink)
yeah had it smoged for warrenty on my engine and they told me it is running rich
__________________
22re w/ RV cam
pacesetter header
K&N cold air
31" cooper stt's
Old 05-18-2008, 02:16 PM   #10 (permalink)
abecedarian's Avatar
Location: Climbing cell towers- the deadliest job in America
running rich (high hydrocarbon emissions/ HC) does not mean that the EGR is bad. running rich at 'cruise' RPM's points a tad towards the EGR but doesn't mean much either though.
Now on the other hand, high NOx readings at cruise would point to the EGR.
__________________
...relax and rest assured: my name is not allan.
Save the world! Protect the environment!! Conserve nature!!!! Eat a vegetarian / vegan.
See, I'm being green.
Quote:
Originally Posted by SwampThing View Post
....But I'm happy to report that I have yet to have a good measure of sense knocked into me. Even when I was testing out my hardhat by runnin full speed into a brick wall, I am still sense-less.
abecedarian is offline
Old 05-18-2008, 02:24 PM   #11 (permalink)
Team420's Avatar
Quote:
If you dont have a cat on the truck...why worry about the egr...just bypass it and call it good, you already fail emmisions tests due to the lack of a cat, or at least in the state of maine you do.
__________________
93 Runner, 3vze, auto, 4.88 gears, 31" tires, mostly stock, 255k and counting
New bitch:
94 runner, 3vze, geared 4.56, m/t!!, 31/10.5/15, only 200k on the clock
Team420 is offline
Old 05-18-2008, 02:33 PM   #12 (permalink)
yes had high Nox reading at cruise! So EGR. Cuz Im about to go out the door and get a new one!
__________________
22re w/ RV cam
pacesetter header
K&N cold air
31" cooper stt's
Old 05-18-2008, 02:42 PM   #13 (permalink)
js9924's Avatar
Quote:
I second this. There is no point in picking and choosing which emissions equipment you want. Also dont forget to check the filter in the modulator before the EGR. Shove a 10 k resistor in the connector for the temp sensor and the code will disappear. click on the link in my sig and you will find a write-up under the projects section.
__________________
'94 T100 3.0
My mods page: http://www.angelfire.com/fl4/dmb
js9924 is offline
Old 05-18-2008, 03:52 PM   #14 (permalink)
ok I dident get a egr because the parts house dident have the gasket for it so I will wait! I looked at the egr mod filter and it looks nice and clean! Im just trying to ge tto the bottem of this stuff. Truck runs good and has good power it just pings a little and throws a check engine light after driving in the highway for a while!
__________________
22re w/ RV cam
pacesetter header
K&N cold air
31" cooper stt's
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
EGR code 71 Alex 400 86-95 Trucks & 4Runners 33 05-09-2008 07:14 PM
EGR what does this control, I have Code 71 simpsons721 86-95 Trucks & 4Runners 15 05-07-2008 10:28 PM
EGR code 71 Alex 400 86-95 Trucks & 4Runners 28 02-18-2008 08:59 AM
EGR malfunction code 71? Silverunner 86-95 Trucks & 4Runners 10 01-19-2007 01:49 PM
EGR Code 71 xentrino 86-95 Trucks & 4Runners 3 11-13-2006 06:26 PM
Advertise on YotaTech.com
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
