Has anyone used a procomp 3inch suspenion lift?
Old 01-29-2009, 11:49 AM
Sammyboy's Avatar
i picked up the front half of the kit, the problem im missing the install instructions, that and i would look to make sure i have all the parts anyone have any experience with this kit? or know where i might be able to get the instructions, pro comps web site does not have them.
Old 01-29-2009, 11:53 AM
abecedarian's Avatar
3"?
what's the application- year, models, etc?
depending on what you have, take pics of the parts and we'll tell you where they go.
Old 01-29-2009, 11:58 AM
Sammyboy's Avatar
95 sr5 pickup ifs
pics will be up in a few
Old 01-29-2009, 12:33 PM
Sammyboy's Avatar
[attach][attach]Has anyone used a procomp 3inch suspenion lift?-toyota-suspension-003-1.jpg[/attach][/attach]
Attached Thumbnails Has anyone used a procomp 3inch suspenion lift?-toyota-suspension-001-1.jpg   Has anyone used a procomp 3inch suspenion lift?-toyota-suspension-002-2.jpg
Old 01-29-2009, 12:53 PM
looks like they came off a SAS vehicle....
okay, let's start with the last pic:
top left- right front suspension knuckle extension
top right- left front suspension knuckle extension
bottom are transmission drop brackets and bushings- IIRC, the one on the left is on the right side of the vehicle and the one on the right goes on the left.
Old 01-29-2009, 12:58 PM
2nd pic-
Top is the front drops and differential mount
bottom is the rear drops and cross brace. that cross brace needs replaced before you even think about installing the kit.
Old 01-29-2009, 12:59 PM
1st pic-
That's all the hardware that bolts the front end together.
Like I said above, looks like you got a take-off. No wonder there's no instructions.
Old 01-29-2009, 01:01 PM
Sammyboy's Avatar
is the cross brace salavagible if i press it straight, and my be welded some plateing or a gusset
Old 01-29-2009, 01:03 PM
You would wait til today to post this.... I'm in Mason, not terribly far from you and could've came over today and helped lay it all out. Maybe if I'm not working tomorrow we can work something out. It's just going to be difficult to explain in the forums because you have some bolts and stuff you won't need.
Old 01-29-2009, 01:04 PM
I wouldn't try. It hit something pretty hard and would likely fracture trying to straighten it. I'm trying to figure out how it got bent and not the front...
And FYI- I have the same basic kit on my 88 (in my avatar). Your's is a 4" lift, Stage 1.
Did you get the blocks for the rear with it too?
Old 01-29-2009, 01:14 PM
Sammyboy's Avatar
no blocks, what happened is i was in a rear end collisions and both my rearend springs are toast, so im planning on ordering new lift spring from downey offroad, since i have to replace the parts any way, i figured why not use a little lift
Dparr2ndgen
09-08-2015 01:06 PM
justdifferentials
09-05-2015 06:52 PM
joeynational
09-05-2015 01:54 PM
matthew138
09-03-2015 08:21 AM
Ryall
09-02-2015 06:48 AM
Quick Reply: Has anyone used a procomp 3inch suspenion lift?
