Got my rims!
Old 08-04-2008, 04:37 PM
Trustyrusty's Avatar
Got my rims!
I got my rims and tires, and test fitted a rim on the front, I got 15x8 3.75" BS and 33x12.5" tires and the backspacing is what most IFS suspension lift companies reccomended, and it seems once I get my tires on my rims they will rub my tie rod? anyone got pics of how close it is?
Old 08-04-2008, 05:01 PM
abecedarian's Avatar
measure from the axle to the upper arm, and then measure from the axle to the tie rod end. bet the upper arm is farther away.
test fit a rim on there and give us a pic.
Old 08-04-2008, 05:08 PM
The rims are getting mounted and balanced right now, theres no way to tell if the tires will hit the tie rod unless its mounted..
Old 08-04-2008, 05:15 PM
i'll tell you now, it won't. relax.
the tie rod end is more inward than the upper ball joint / control arm end.
it looks close, like it sticks out farther, but it's closer to the axle.
Old 08-04-2008, 05:38 PM
Jay351's Avatar
Yep, it wont Stock backspacing is 4.75 and I have seen 33x12.50" mudders on thoes without rubbing.
You will probibly rub on the inner fender/pinch weld area.
Yes, that spacing will clear all IFS lifts available.
Old 08-04-2008, 06:42 PM
I beat the pinch weld down towards the bottom, but I only went up to the bolt hole for that screw to hold the inner fender on, is that enough? I did that earlier today, I was just afraid once I got my tires tommorrow it would hit the tie rod or somethin, oh and do you think I could run these without any lift until I get my lift on? Or would it rub ALOT?
Old 08-04-2008, 06:46 PM
if the sway bar is on and the bushings are good, you'll only rub if you hit a good bump with the steering wheel 3/4 of the way to one side or the other.
... i hope.
my tires are about 31 and had about 1" clearance at full lock.
Old 08-04-2008, 07:25 PM
Jay351's Avatar
Yes, you will rub pretty good. My combo (wheels stick out another 1/4 inch) I rubbed with a 3" body lift over any bump with the wheels turned.... Just don't go wheeling or anything and go SLOW over bumps (when your wheels are turned)
Old 08-04-2008, 10:11 PM
just a 22re's Avatar
the tie rod is on the inside of the rim you dont have any problems with that one my friend
chukarhunt
12-08-2019 11:39 AM
1uzRunner
63
11-10-2018 03:58 PM
Cycles
09-29-2015 06:37 AM
Bill McBride
09-20-2015 02:51 PM
AkitaDog
09-03-2015 09:01 PM
Quick Reply: Got my rims!
