gm 350 engine swap questions.
Old 09-29-2010, 12:05 PM
95blackToy's Avatar
im looking at doing a 350 chevy swap. Im looking here http://www.northwestoffroad.com/part...ladapters.html Does anyone for sure know if a 4 inch body lift is really necessary to go off-road? And how do i tell if my bell housing is removable? I dont see any bolts but maybe i am just missing something. Also would i have to get a new speed sensor, and what about my tachometer?
Mods please fix my title thats suppose to say "350 swap questions"
Old 09-29-2010, 12:14 PM
blake.nemitz's Avatar
i had one when i put a 383 in my sas'd 88. if your running ifs you can mod your oil pan to mount the motor farther down but i had a two in body lift and with the straight axle everything cleared fine i just welded the chevy mounting pads directly to the 22re frame mounts and voila enough room for a pusher fan and the distributor. if it were me i would go with a 302 not because im a ford guy :im not: but the dist is in the front instead of the back and then you could mount the block farther back. i also used a th350 trans with a 205 tcase so it was all chevy, it was cheaper than buying adapters and i just had to tweak my driveshafts a little
Old 09-29-2010, 12:39 PM
2DoorRunner's Avatar
Dont go through NWOR. Bad customer service, and their stuff is crazy expensive. Advance adapters is the way to go.
To stuff a 350 in an ifs truck you will need a bracket lift, and a 2-3 inch body lift unless you want to modify the firewall with a big ass hammer
Download the manual on 6 and 8 cyl swaps from AA. Or order the hard copy, its a good one to keep in the bathroom.
Also, search the domestic engine swap section, there is tons of info on it.
Old 09-29-2010, 05:53 PM
95blackToy's Avatar
what exactly is a bracket lift? also how far forward would the motor be without screwing with the fire wall? would it even fit?
Old 09-29-2010, 05:54 PM
xxxtreme22r's Avatar
this makes me wish I took better photos of an IFS 4runner with 350 at a local mud bog. I was more in awe of the fact it was still ifs and did not look much further to see what he had for a lift on it etc etc. all I know is it can be done with IFS, have seen it personally.
Old 09-29-2010, 06:00 PM
camo31_10.50's Avatar
you do realize theres an entire folder dedicated to motor swaps right?
even one narrowed down to Domestic swaps (as in american motors.)
Old 09-29-2010, 06:27 PM
Let me be more clear. You need a lift that comes with a big diff drop (not the 1 inch one). You need it to drop down the front diff to clear the oil pan.
You dont have a choice of motor mount placement. The ifs set up keeps you from welding on mounts, but im sure you could figure out some custom mounts.
Also, the 350 is long, so moving it forward will give you problems with radiator clearence.
Have you thought about a 4.3 v6? Its a 350 with 2 cylinders chopped off.
Old 09-29-2010, 06:28 PM
And yes, as stated by me and camo, search. It will give you an idea of how much work a 350 swap actually takes.
Old 09-29-2010, 06:38 PM
95blackToy's Avatar
i looked and couldnt really find any actual swaps all the way through. i meant back not forward about the firewall.
Old 09-29-2010, 07:05 PM
TOYOTA 1's Avatar
i had one in my 86. i put Chevy motor mounts directly on the factory frame mounts.
i used a 3" body lift only. i also used a corvette water pump/pulley system that allowed me to run a dual core cross flow radiator with a manual fan. i ran a turbo 350/205 combo. 33's and 410's!
use a small dizzy and you wont have to beat in the firewall. i had to modify the oil pan slightly to clear the ifs chunk.
it is a pretty simple mod i thought.
did i mention how fun it was to drive?
Old 09-29-2010, 08:40 PM
kiyobrown's Avatar
If you are this far along in the process and you have this many questions, its time to try and hook up with someone local, sounds like you will need help if you go this route.
Old 09-29-2010, 08:45 PM
totally a bro
Staff
vital22re's Avatar
lets keep this on topic and NO DRAMA!!!
Old 09-29-2010, 08:47 PM
Old 09-30-2010, 05:25 AM
95blackToy's Avatar
Thanks guys and I'm not very far along. Still got to get. an engine. I'm not prepared for it quite yet
Old 09-30-2010, 05:45 AM
meswoleshane's Avatar
My ext. cab has a 3" body and a 4" suspension lift. 350/th350/203
Old 11-09-2014, 03:43 PM
greaseball's Avatar
who is aa besides alcoholic anoymus
Old 11-09-2014, 04:04 PM
JasonYota's Avatar
Here's another one.…
Old 11-14-2014, 12:48 PM
kcaudill's Avatar
Advance adapters = AA
http://www.advanceadapters.com/
bigjstang
08-25-2021 12:41 AM
icentropy
09-16-2020 02:47 PM
mskalmus
05-28-2017 07:51 AM
steve miller
10-10-2015 01:40 AM
coryc85
09-09-2015 06:24 AM
Quick Reply: gm 350 engine swap questions.
