getting 33" to work correctly with my 2nd gen runner
Old 10-02-2008, 11:31 AM
Matt16's Avatar
Originally Posted by Noltz
Agreed. 2" body lift, slight trim of the valence in the front. Also provides room for transmission work, allows you to lift the tank up too, should you want extra clearance without the high COG.
Sadly, you can't lift the gas tank on a 2nd gen 4Runner. The upper control rod mounts to the frame a couple inches above the gas tank, the the suspension is at full droop, I think it uses up that room.
Old 10-03-2008, 02:16 AM
n16ht5's Avatar
Originally Posted by tc
Switch to 33x10.50 - all the traction and ground clearance, none of the fitment issues.
why would he go to all that work just for that? hes not asking to switch tires.
I have 33x1250s, I dont rub in the front at all (cept touching mud flaps)
trick is the backspacing it seems. I have stock FJ wheels and everything clears nicely. the rear rubs on the frame a bit
if not try bump stop spacers. should only need 1/2" or so to prevent the susp from going up so much
marcusSRG
06-27-2015 07:13 AM
Niameyrider
06-25-2015 05:50 AM
infinityisfive
06-16-2015 06:51 PM
peterbilt
06-11-2002 10:28 AM
95Runner
06-09-2002 08:56 AM
Quick Reply: getting 33" to work correctly with my 2nd gen runner
