gear oil in the steering box?
Old 12-28-2011, 06:19 PM
az_eaglescout_pilot's Avatar
just finished putting my steering box back together after putting new seals through the entire box...did it all with this link: http://128.83.80.200/TACO/box.html
however when i looked at the FSM it said that i should "replenish steering gear with gear oil" and that it takes 400 cc of it. is this truly necessary? i thought that ATF was the lubricant in the steering system. if i do need to put some gear oil in what weight? this was not mentioned in the link above, and im pretty sure he hasn't had problems with it.
Thanks,
Jordan
Old 12-28-2011, 06:59 PM
Staff
DeathCougar's Avatar
Gear oil is used if you have MANUAL steering only.
ATF is used if you have POWER steering.
smthwsn357
12-04-2023 02:08 AM
mskalmus
05-28-2017 07:51 AM
jerusry
10-19-2015 05:28 PM
87blyota
07-10-2015 04:31 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: gear oil in the steering box?
