Gas Mileage '94 toyota p/u 4x4 22re
Old 12-15-2011, 05:09 PM
Moonfish's Avatar
This thread is from 2006.
The fancy air filters are known to screw up the MAF sometimes.
O2 sensors go bad and don't throw a CEL.
40 psi in hiliux tires = a sadist.
Old 12-16-2011, 12:03 PM
flatbed's Avatar
-Error code 21 came up for my O2 sensor. Does that count or is it only pertain to the heater circuit to the O2 sensor?
Old 12-17-2011, 11:07 PM
mudweiser8801's Avatar
Have a 94 p/u 22re 4wd, 4 inch suspension lift. 31.10.50's. With 4.56 gears only 58,000 miles on mine. I put $40 @ 3.26 a gal. An I get roughly 188 miles. Havent switched to synthetic oil yet.
Bad?? Good?? Average?? This is my daily driver an I do 80% city driving
I'd appreciate any input
Old 12-18-2011, 06:51 AM
Moonfish's Avatar
You should be a 3rd grade math teacher!
Old 12-18-2011, 03:12 PM
  #25
Really that's what you came up with moonfish??
Old 12-18-2011, 09:12 PM
  #26
XtraSlow_XtraCab's Avatar
1987 Toyota 4Runner 22re 5 speed.
The original sales brochure suggests 18 city/24 highway or something in that vicinity. I was in that ball park before the 32 inch tires, but I'm stilll ok. Probably 17 city and 21 highway. Use that as your "should be" point.
Mudweiser- Moonfish is bashing you because you provided all of the information needed to do TWO basic arithmetic functions and asked someone else to find the answer. Get a calculator BTW, price doesn't effect fuel efficiency so quit making me feel bad for paying BS Californian gas prices
MILES DRIVEN/GALLONS USED
Old 12-18-2011, 09:17 PM
  #27
just posting my info obviously Ive calculated my MPG just curious if 15mpg is bad, thanks
Old 09-22-2014, 08:34 AM
  #28
bobby511's Avatar
87 Toyota 4X4 SR5
I just had my 22re top end of the motor rebuilt and the bottom end was rebuilt about 30,000 miles ago. I also had a new transmission put in it. I filled it up on Thursday (it costed 42.00) with a 15 gallon tank and i went 60 miles and it has killed 1/2 a tank of gas. i calculated it and it is getting about 8 mph.... I changed the timing to 5 degrees like it is supposed to be and i changed plugs and wires along with running fuel injector cleaner through it and replaced the o2 sensor. I am still getting 8 mpg and the truck is burning rich. Does anybody know why? I need help desperatly!!!! i drive 30 miles round trip to work and back every day
Old 09-22-2014, 08:53 AM
  #29
Schnayke's Avatar
I would probably make a new thread this is a very old one and will likly get you less response's because of that.
Old 09-22-2014, 10:06 AM
  #30
Kiroshu's Avatar
Wow this thread is ancient.
Old 12-19-2015, 08:30 PM
  #31
mantree's Avatar
I am geting about 11 right now and the truck is real slow and bucks when you let off the gas, I don't have any exhaust right now as the cat when bad and all I could do was unbolt it befor that I averaged 17 to 19 with 31s and 3.10 gears but I am very heavy on that skinny one on the right
Crazy_Guy97
12
06-24-2015 04:02 PM
BTOWN4RUNNER
13
06-10-2002 06:33 PM
stretch786
06-04-2002 03:22 PM
Quick Reply: Gas Mileage '94 toyota p/u 4x4 22re
