Gas leaking and hard to start
Old 12-25-2008, 04:00 PM
tiggersdesire's Avatar
Wink Gas leaking and hard to start
Hi all, my 1992 sr5 4x4 developed a gas leak from the top of the tank and the truck is getting harder and harder to start. I can see the top of the tank and the tubes coming off the top unit look corroded. Is it a pump or vacuum line or sending unit line that must be leaking and causing the hard start. I am going to drop the tank and take a better look. Any info from you guy's would be greatly appreciated!!
Thanks much
Old 12-25-2008, 05:57 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
The pressurized pump line to the motor. You have a leak, so you're losing fuel pressure. Very common area to spring a leak. It's coming off of the fuel pump mounting bracket and you'll need to replace it if you can't fix the leak.....ie. the line is too corroded and will just break even further in the future.
Old 12-26-2008, 11:13 AM
Thanks Matt
The pump unit is on top of the tank I presume, that seems to be where the gas is leaking from. Then I drop the tank to get at it?
Thanks much Matt, Cheers
Old 12-26-2008, 12:12 PM
thook's Avatar
The pump itself is in the tank. What you see on top of the tank is the top of the mounting bracket that submerges into the tank (with the FP attached) and covers the hole.
Yes, you'll need to drop the tank.
http://personal.utulsa.edu/~nathan-b...28fuelpump.pdf
If the connection of the pressure line to the line on the bracket look seriously rusted, start spraying the connection and FP bracket screws (fastening the bracket to the tank) with penetrating fluid. Thrust or PB blaster are often recommended. Tap the connections with a hammer to set up vibration and relieve surface tension. Try not to damaged the connection so as not the strip. May happen anyway if they are terribly rusted.
Anyway, if all goes well enough once you have it apart, all you'll need to replace is the bracket. Some would go so far as to replace the pump while your in there. Up to you and your budget.
Note: There's a drain plug on the fuel tank for your convenience. Soak all bolts will fluid and tap before you start. Unless, they actually look they will come loose easily.
Good luck.
JF9243176
10-08-2017 04:21 AM
jennygirl
11-17-2015 11:24 AM
bigblue82
10
07-06-2015 08:27 AM
serenity03k64
06-27-2015 07:59 AM
JF9243176
06-24-2015 04:53 AM
Quick Reply: Gas leaking and hard to start
