Fuel Pump
Old Dec 14, 2007 | 09:22 AM
liferunner2's Avatar
Fuel Pump
Hey, I'm trying to disconnect my fuel pump to relieve the pressure in my EFI so that I can get in there, but I can't seem to find a way to cut power to the pump, how can I do that? Thanks.
Chris
Old Dec 14, 2007 | 09:27 AM
rdlsz24's Avatar
You can pull the fuse I believe.
Rob
Old Dec 14, 2007 | 09:31 AM
That's what I thought, but I can't find a fuel pump fuse. There's EFI, but I need it to run in order to depressurize the system. Any other ideas?
Chris
Old Dec 14, 2007 | 12:30 PM
iwilder's Avatar
If I understand your post correctly you are trying to run the engine to use up the fuel in the line as a way to depressurize the system. You could lift the rear seat and on the passenger side, under the seat, there is an access panel with three screws in it. Remove the panel and unplug the connector. This will disconnect power from the the fuel pump. If you do this while the engine is running it will slowly die as the fuel is used up.
Or you could turn off the engine and use a socket wrench to loosen the bolt below the fuel pressure regulator or at the cold start injector. Some fuel will spray out so cover the connection with a cloth to catch the fuel. No smoking or open flames. This is the normal way to do it.
I hope this helps.
Ike
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Fundy Rider
Jul 16, 2015 01:35 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
