fuel line order
fuel line order
I put a new gas tank in my truck (1988 V6 sr5 pickup 4x4 xtra cab) and need to know the order of the fuel lines. The send I have on because that only goes to one spot, I mostly need to know where the other lines attach to?
from the back of the truck there is the fuel send, then fuel return on the fuel pump housing unit and then a third hose attachment on the tank. Of the last two, where do I plug in the line from the EVAP charcoal cannister?
And yes in the future I will label all lines and such.
Cross posted in the newb section with zero thread views and I need this done before tonight.
Gosh, you waited one whole hour! I would demand my money back.
http://personal.utulsa.edu/~nathan-b...91fueltank.pdf
By the way, you're more likely to get help (at all) if you proof-read your posts. "The send I have on ..."?
TURBOrunnerNM
07-22-2015 11:01 AM
