Fuel leak from charcoal canister
Old Jan 26, 2015 | 06:17 AM
GrumpyTruck's Avatar
Hey guys,
I was driving my 94 toyota pickup on the highway and noticed my truck surging and losing power. I pulled off and found fuel leaking out of what I assume is a vent hose that comes out the bottom of the charcoal canister. Can anyone tell me what is the cause of it? I thought maybe a bad fuel pressure regulator but when I take the vacuum hose off the FPR, there is no fuel in it.
Thanks!
Old Jan 26, 2015 | 06:24 AM
bswarm's Avatar
Did you overfill your fuel tank?
Old Jan 26, 2015 | 06:46 AM
Not that I know of. No fuel ever flowed out of the filler neck when I put gas in it and I stopped when the pump shut off.
Old Jan 26, 2015 | 06:56 AM
scope103's Avatar
If the vacuum line from the canister to the Thermal Vacuum Valve to the throttle body is disconnected, you won't have flow to remove the fumes condensed in the canister. Eventually enough fuel accumulates that it has to go somewhere, which is out the bottom (which is actually the air intake when you have vacuum).
Assuming you have the 3VZE, the TVV is a weak point. It is in a hellish environment, the plastic deteriorates, and one or both of the nipples can break off. Some on this site have repaired them, but they are only about $52 at the dealer.
http://personal.utulsa.edu/~nathan-b...76evaporat.pdf
Old Jan 26, 2015 | 07:00 AM
I have the 22RE, could it still be the same problem? Also, you're saying the there shouldn't be an open ended rubber hose coming out the bottom of the canister? It should be attached to the throttle body?
Old Jan 26, 2015 | 07:04 AM
bswarm's Avatar
It's probably a clogged filter or stuck check valve, both inside the canister and not serviceable. Replace it with a new one.
Old Jan 26, 2015 | 07:07 AM
bswarm's Avatar
There should be 2 hoses on top, one goes to the intake, the other to the fuel tank. The one on the bottom is a vent.
Old Jan 26, 2015 | 09:38 AM
scope103's Avatar
No TVV on the 22re. http://personal.utulsa.edu/~nathan-b...17evaporat.pdf Otherwise, pretty much the same.
The manual gives a test procedure. If it were me, I'd test the old one before dropping $250 on a new one. http://www.toyotapartsoverstock.com/...modelYear=1994
Old Jan 26, 2015 | 09:46 AM
Thank you! I will try what the link says
Old Feb 19, 2018 | 05:40 PM
jwicker's Avatar
Bringing this thread back from the dead.....
What was the verdict?
I'm going to look at a 1994 22re with the same issue Thursday. Don't want to make an offer if it's a major issue.
Thank you in advance.
jwicker
Old Feb 19, 2018 | 05:49 PM
Whore_runner16's Avatar
What could this leak be from? It’s clear.
My car also makes a weird whistling sound when accelerating.
I have a 2006 4Runner sport edition 2wd
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
raptor510
Feb 17, 2017 07:11 AM
94whiterunner
Jul 12, 2015 07:15 PM
nick b
Jul 11, 2015 04:38 AM
