fuel injector problems?????
Old Jan 22, 2008 | 06:46 PM
weakyota91's Avatar
so i picked up this little 92 pickup with a 22re anyways it ran really bad .
i found the air flow meter was bad/replaced it. but now it seems like it only runs on 2 cylinders #2 and 3. while it was running i pulled the plug wires off 1 and 4 and there was no change in the way it ran. but if i pull them off 1 0r 3 the engine dies. i checked spark and it looks good. when i pulled the plugs 2 and 3 looked normal like they were firing but 1 and 4 look carbon fouled im thnkin for some reason those injectors arent working. if anyone could help me out here id appreciate it thanks>
Old Jan 22, 2008 | 09:00 PM
thook's Avatar
Kinda sounds like it. The only way to really know for sure is to test them. You could try running some cleaner through first and see if that helps.
jbv808
Aug 6, 2021 04:47 PM
Eggslinger
Jun 8, 2019 03:32 PM
Doug4320
Mar 24, 2018 10:11 PM
steve miller
Oct 10, 2015 01:40 AM
karbin
Jul 5, 2015 11:37 PM
