fuel door lockcylinder
Old 11-25-2013, 12:51 PM
bbrideau's Avatar
Is the lock cylinder on the fuel door the same as the ones in the doors?
Truck in question is 88 4runner sr5, 22re if that makes any difference.
I cna find door lock cylinders but no fuel door cylinders. Can't seem to find a kit either with the door locks and ignition cylinder all keyed the same.
Note: i have not talked to toyota yet about a lock set, not sure if they have them still or how much they would cost.
Old 11-25-2013, 01:29 PM
wyoming9's Avatar
Red face
Decide just what key you want to unlock everything pull all the lock cylinders.
Go to your local lock smith
Get all the cylinders keyed the same.
I doubt Toyota has a full lock set it would be one piece at a time. then expensive.
Old 11-25-2013, 05:01 PM
1993 4x4's Avatar
My 1993 is. The ignition, doors and fuel door are all the same
Old 11-25-2013, 05:11 PM
slacker's Avatar
I think what hes asking is if the cylinders are interchangable ?
and no a direct replacement , but can be made to work
I have a couple of complete truck lock sets , but no 4runner sets
Old 11-26-2013, 07:31 AM
fdp101452's Avatar
I bought a lock set for my 90 pickup from Toyotapartscenter.net about 2yrs ago, so you may still be able to get oem.
Old 11-26-2013, 09:00 PM
4digger's Avatar
When mine broke I went to Home Depot and bought a cabinet lock and it fit in there and works perfectly fine. however if you don't want to take the cheap way out heres the lock for your runner. http://www.ebay.com/itm/Toyota-4Runner-Pickup-Gas-Fuel-Door-Lock-Cylinder-with-Keys-Factory-NEW-/161156622422?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AToyota%7CModel%3APickup%7CYear%3A1988&hash=item2585aee856&vxp=mtr
Old 11-27-2013, 01:39 AM
RAD4Runner's Avatar
Cylinders do not look interchangeable.
Old 11-27-2013, 08:40 AM
bbrideau's Avatar
Didn't think they were interchangeable, i didn't want to have to take them all to locksmith and have them re-keyed, not that its expensive just a pain as i live in small town thanks for the ebay link on the gas door lock.
I havn't looked at removing the door locks but i would hazard a guess and say that on the inside of the doors theres tabs on the lock cylinder to remove it? or is there more to it then that?
Old 11-27-2013, 09:08 AM
RAD4Runner's Avatar
Removing Door Lock Cylinder Simple To Do
Very easy to remove. See FSM for for procedure for accessing door.
Tools needed:
  • Rag. Yes, rag to remove clip that holds door crank,
  • Philips screw driver for a few screws.
  • Rope or good friend with a beer. He holds beer with one hand and the door panel up with other hand at window level while you work
  • Very fine long-nose pliers for removing and re-installing clip-ring that holds door lock mechanism to cylinder.
  • 10-mm socket & ratchet, in case you want to remove window regulator to lubricate/inspect
  • Clean floor with no cracks/grate/etc so you do not drop and lose clips
  • Most importantly quick and sharp eyes to see where clips went flying to - LOL!
Supplies:
  • MP Grease. Not for door cylinder but good idea to lubricate the window regulator while you're in there.
  • Oil/Silicone sparay to lubricate door cylinder
  • Some plastic material or tape to mend waterproofing sheet if needed. I use Polypropylene document protector.
Happy Thanksgiving, guys!
Old 12-01-2013, 10:20 PM
SX200's Avatar
I looked at installing a lock.
I poped a magnet behind the flap just above the lock hole.
Keeps it closed and was cheap, I also put a rubber grommet in the hole made it look tidy.
westonian18
05-01-2020 06:38 AM
TDonkey
07-26-2015 10:14 AM
britishdudes2dr
07-25-2015 06:47 AM
94yotaky
07-23-2015 07:50 AM
Quick Reply: fuel door lockcylinder
