front stub shaft removal with a locker in there
I'm trying to get the stub shaft off of my front IFS since the axle seal is leaking. I read somewhere that there is supposed to be a C clip holding the axle in there but for the life of me I can seem to see it because of the lockrite that's in there.
Do I have to pull the locker to get the stub shaft out? Please tell me no.
check this page out.
http://www.gearinstalls.com/ifs.htm
from zuks site .
just use a large screwdriver.
from zuks site .
Thanks!
Got it! Now I'm glad I did since I now know that there isn't an axle seal in there and the freaking third member has sand all in it....
Thanks again.
Thanks again.
FYI, you can often get those shafts out by using a block of wood and a BFH. Angle a length of 2x4 against the back side of the flange and smack it as best you can to unseat the spring clip holding the shaft in.
When I did my lockright I used the BFH technique, along with a big pry bar. Loads of fun.
You can get the axle seals at the dealer, I replaced both of mine when I had it apart.
I did something similar. I used a dead fall hammer and after two hits it pulled out. So easy.
jerusry
10-19-2015 05:28 PM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
FS[NorAtl]: some RC stuff crawler and racer
akaphilly
07-09-2015 02:34 PM
