YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-18-2008, 02:45 AM   #1 (permalink)
Front end noise when wheels turned
While on some trails tonight, I encountered a bit of a problem. I hit a puddle that was about a foot deep going 20 and now when i am stopped, and i turn the wheel either left or right, there is a loud squeaking noise coming from the front end. When I turn the wheel left or right and I hear that noise, the steering wheel shudders. Any ideas as to what could be causing the problem? My 2nd gen 2WD 4runner is stock except the 32" maxxis bighorns and the torsion bars are cranked.
Thanks for help in advance.
Lbeezy is offline
Sponsored Links
To remove this ad, register today!
Old 05-18-2008, 04:43 AM   #2 (permalink)
bigt's Avatar
all my 4wd 4runner have always made noise if you turn the wheel all the way and turn like a grinding rattle...
but as far as being stoppped is your power steering pump making the noise??
__________________
1991 HILUX SURF SSR-X
2-lte turbo diesel with upgraded head
tons of cool options you dont get in north America
RIGHT HAND DRIVE,auto,push button 4wd,turbo timer,31.1-.50.15 bfgs,factory fender flares,window flares.
2 kick cvrs 12 inch rockford 600d
sirius TUNED TO HOWARD 100
trail ifs rig
94 gold 4runner
22re no options
32.11.50.15 MUD KINGS
aisin hubs,WELDED rear
homemade snorkel
cb radio
blue 93 srf 4runner .. was running last week now a parts truck.. parked
bigt is online now
Old 05-18-2008, 05:00 AM   #3 (permalink)
Crawdad's Avatar
You got the belt wet or muddy, the belt is slipping causing the squeaking. The slipping belt means the power steering is cutting in and out causing the steering wheel to shudder.
__________________
1990 4Runner 3.0/AT/4WD - 285/75/16 TreadWright D-Muds, SDORI Coil Spacer, Aisin Hubs
2005 Mazda 6i 2.3/MT
Crawdad is offline
Old 05-18-2008, 06:25 AM   #4 (permalink)
4Mogger's Avatar
Something to check...
The water could have washed the lube off of the steering stops.
There are two per side and are easy enough to get to...just find the steering stops (from factory they have plastic caps on them but they quickly wear through and fall off) that are basically a round-headed bolt that contacts a half-moon shaped ramp type stop. Just take some grease and apply it to the bolt and steering stop with your finger. You will have to reapply at appropriate intervals or daily if you drive in water.
4Mogger is offline
Old 05-18-2008, 10:24 AM   #5 (permalink)
iamsuperbleeder's Avatar
Send a message via Yahoo to iamsuperbleeder
Quote:
excactly as I was going to say...
__________________
91 Pickup, 4wd, 22re, stock suspention, rollin on 31s... for now that is...
288 thousand miles and counting...
Linkies:
YotaTech photos
MySpace
Quoties:
Quote:
Originally Posted by DeathCougar View Post
Take the oil cap off and throw it away, you dont need that. May as well drain the oil, dont really need that either. Just extra weight, and without that extra weight, you'll gain like, 400 horsepower!
Quote:
Originally Posted by toomanytoyotas View Post
4 tires in the air is o.k., so long as they are closer to the ground than your roof is...
I'll hit 1,000 posts before long...
iamsuperbleeder is offline
Old 05-18-2008, 10:51 AM   #6 (permalink)
abecedarian's Avatar
Quote:
Me too. Particularly considering 32's.
__________________
Quote:
Originally Posted by SwampThing View Post
I'm really starting to hate being bent over all the time.
Quote:
Originally Posted by BoostinChick View Post
It's ok I don't have boobs either Allan.
Quote:
Originally Posted by YotaTech Moderators
What do you mean we have a chat room? What's the URL?
Oh, here it is:
http://www.yotatech.com/misc.php?do=flashchat
abecedarian is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
When wheel is turned knocking noise from front right of axle thewjsand 84-85 Trucks & 4Runners 10 04-17-2008 04:54 AM
Front end noise jkirk 95.5-2004 Tacomas & 96-2002 4Runners 3 08-30-2004 03:43 PM
Front End Noise Cebby 95.5-2004 Tacomas & 96-2002 4Runners 5 02-09-2004 03:19 PM
Front End Noise HammerDown6 95.5-2004 Tacomas & 96-2002 4Runners 15 11-27-2003 07:20 PM
Front end noise Cebby 95.5-2004 Tacomas & 96-2002 4Runners 2 12-30-2002 09:18 AM
Advertise on YotaTech.com
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
