Front Drive train questions HELP!
Old 05-24-2009, 09:40 AM
Azca's Avatar
Hope all of you are having a great weekend.
I have been attempting to figure out what is causing a high speed vibration for some time and unfortunately I think I found it.
On the passenger side where the drive shaft connects to the differential there is what I believe to be a significant amount of play. It moves in all directions abour a 32nd of an inch. I would think it should be solid.
Is this normal? If not I would think I have some issues and need to rebuild the front diff.
Any thoughts from you folks would be appreciated!
Old 05-24-2009, 10:20 AM
toyNG's Avatar
Sounds like a u-joint problem. Since it's a cheap fix, I'd start there. Here's a link to where you can get one. http://trail-gear.com/driveshaft.html
Do a quick search on u joint failure and see what you come up with.
Old 05-24-2009, 11:04 AM
orbital02's Avatar
ditto
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
lledwod
08-30-2016 01:03 PM
God's Bounty Hunter
07-08-2015 12:54 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: Front Drive train questions HELP!
