Front brake uograde
Old 07-29-2015, 09:17 AM
garagespace's Avatar
Hi. ... I have a stock 1986 ifs 4x4 22re 5 spd pickup (15" rim) . My front caliper froze and rotor is warped. What upgrade can I do WITHOUT UPGRADING THE MC OR BOOSTER. I was looking at the 1992-95 4Runner or T100 rotors and calipers, as I have read they might be a bolt on upgrade. Which year 4runner/t100 will work? (+ trim backing plate) Anyone have exact part numbers ?
Old 07-29-2015, 01:14 PM
wyoming9's Avatar
Red face
One needs to use care some of those brake upgrades will not work with some 15" wheels.
I know with the Tundra calipers one needs to go to 16" wheels.
I can`t get excited about brake upgrades I just keep my brakes in good repair makes it easier for me to know what is on there.
Do Yourself a favor stay away from T100 parts they can be hard to find even simple parts at times.
Old 07-29-2015, 06:45 PM
donomite49's Avatar
V6 calipers.
I found 95 4runner V6 calipers with new rotors for cheap at the local pull a part.
They have 4 large pistons vs the 4 cylinder has 2 large pistons /2 small pistons.
Old 07-29-2015, 08:34 PM
millball's Avatar
I put '92 4Runner V6 rotors and calipers on my '87 4Runner without changing the master cylinder and I am happy with the brake action and feel.
It was a braking improvement for me. Greater braking force with less pedal pressure.
Sometimes when you change to a larger master, you shoot yourself in the foot, defeating the advantage of larger diameter caliper pistons when you increase the master cylinder diameter as well.
I had a wrecked '92 V6 on hand, and when the '87s' wheel bearings needed service, I just changed over, hub and rotor complete, and caliper.
I am running 15" first gen SR5 alloy wheels on the '87 with the newer brakes.
I did have to trim the backing tin a bit with an angle grinder to install the larger calipers, but no biggie.
Sorry I can't help with part numbers.
Old 07-30-2015, 02:05 PM
maco35's Avatar
I did a full V6 brake upgrade out of a '95 4runner and the stopping power increase was really amazing.
Old 07-30-2015, 09:24 PM
Thanks !
I'm looking at a set off a 93. 4x4 4 Rumner to swap over.
Old 10-11-2015, 03:53 AM
Odin's Avatar
Are the 89 V6 rotors and calipers the same or will it need to be newer stuff?
Old 10-11-2015, 07:58 AM
millball's Avatar
I don't know for sure. The '92 4Runner rotors and calipers that I installed on my '87 are larger than the stock ones that came on my '87 Runner for sure.
I was lucky to have a '92 wreck to take them off of.
I think I read that a brake change was made starting with the 1992 models, but what really is on the earlier 2nd gen models, I can't say from personal experience.
Old 10-11-2015, 09:45 AM
Odin's Avatar
I think I remember seeing something like F16Q or F18Q on the 2wd truck I was eyeballing.
My truck is a 91, 2wd.
Old 10-11-2015, 09:57 AM
millball's Avatar
About all I can say is that the stock '87 calipers have two large and two smaller pistons, while the '92 V6 calipers have 4 large pistons.
The '92 V6 rotors are of greater thickness than the '87s', so the calipers and rotors had to be changed as a set. I just changed the hubs complete.
I would'nt take it for granted that 2wd and 4x4 brakes are the same.
Old 10-11-2015, 10:59 AM
Odin's Avatar
After reading a bit I find the F18Q calipers are a still a two piston caliper but they are a little bigger than the 22re stuff. Apparently the rotor is bigger too.
Now I'm wondering about the 92 and newer 2WD V6 calipers and rotors lol
Flying91
45
04-11-2024 04:39 PM
06-01-2021 01:51 PM
jasonty
41
12-23-2018 01:00 PM
09-04-2015 09:27 AM
terminator
07-27-2015 07:13 PM
Quick Reply: Front brake uograde
