Fresh 92' 22re Wont Start. WEIRD.
Old 12-07-2012, 11:45 AM
FuzzyMcFuzzums's Avatar
Okay, it had 204k on it, decided to machine the block. Then I bought a complete head from LC (Street); put everything together. So now it just spins over, it has spark; Its getting gas from the main line; I checked my dizzy several times, and the mechanical timing on the cam (dot to dot). Put the dizzy on @ TDC #I've checked all my grounds. The only part I've had trouble is the wiring harness; but I referenced the forums from my phone and got everything plugged up correctly. I'll have pics up; but I need IMMEDIATE help. I don't know much about these engines; especially the vacuum lines. For example: WHAT IN THE HECK IS THE "GAS F." or at least thats what its called under the hood on the diagram. Please Help. Plus on occasion there is a backfire like phenomenon (lol) coming from the intake.
Last edited by FuzzyMcFuzzums; 12-07-2012 at 11:46 AM. Reason: Forgot important detail.
Old 12-07-2012, 12:24 PM
EFI85's Avatar
maybe your dizzy is 180 off ..when I did mine I had the same issue and I swore I checked and double checked and I was wrong . flipped it 180 and it fired right up
Old 12-07-2012, 12:49 PM
snobdds's Avatar
Your timing is off..
Only a 22r gets the dizzy inserted at 0* or TDC. You need to insert the Dizzy at 5* BTDC on the COMPRESSION stroke.
Old 12-07-2012, 02:08 PM
Okay, so since I set my cam gear and crank pulley dot to dot, im confused on this. Should I spin the crank 180? or spin the dizzy 180? (LOL redundant)Please elaborate on here. I never dealt with this; <3 Chevy. Plus I moved my cam up, from the factory .280 I believe, to a .440.
SubiKing
08-21-2021 03:57 AM
jasonty
41
12-23-2018 01:00 PM
Doug4320
03-24-2018 10:11 PM
Iceman4193
08-28-2015 08:43 PM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: Fresh 92' 22re Wont Start. WEIRD.
