Ford EDIS4 crank trigger question to 22R pulley
How much clearance is behind the crank pulley and the oil pump? The reason why I'm asking is because eventually I want to fit a 36-1 crank trigger wheel behind there. I would measure it myself, but I'm in Iraq.
So right now all I'm doing is ordering parts online and waiting until I get home to have at it With so many ignition options I've decided to go the EDIS route. For starters it's very accurate since there is no slop associated with the stretching of the timing chain and wear of the distributor gear. Also the EDIS module has a limp home mode in case it quits receiving the timing advance signal from the megasquirt ECU I'll be running. Here is an example of how I want to mount the trigger wheel. The pulley is off an 18RG? Found it on a Celica forum. Any help would be appreciated!
dinks07
07-15-2015 05:34 PM
