first gen 4runner tow hitch
Old 06-14-2013, 11:06 AM
foppert's Avatar
Hey guys sorry to bother everyone, but i have been searching high and low and i cant seem to find a picture of how a tow hitch mounts to a stock first gen runner. I am looking to find a used hitch or one out of a junkyard. would a hitch of off a second gen p/u work? From what i have seen the body mounts would get in the way of a normal mount, and the stock 4runner bumper mounts to the body so how do you guys have your hitches mounted?
Old 06-14-2013, 12:10 PM
Philbert's Avatar
They bolt to the frame. Take a look at your frame rails in the rear, on the outside part, near the bumper. There should be at least 2 threaded holes there, for bolts to hold a tow hitch to.
This is how mine is mounted on my 87, and how my buddy's was mounted on this 97 (I helped him mount it).
I would search for aftermarket hitches and see what compatibility they have with 1st gens and other 4runners/trucks to see what model years would have overlap.
Old 06-14-2013, 01:23 PM
wyoming9's Avatar
Red face
Most Hitch brackets mount to the same holes as the bumper on a 87.
Just where do you live Getting the old bolts out can be a real pain if your in the great salt belt.
Easy to make your own receiver hitch.
If you buy a used one make sure all the bolts are loose or you will never get it to line up
Old 06-15-2013, 07:46 AM
jumper_bob's Avatar
Hi foppert.
Yah like those guys said, the factory hitch slides into the framerails, and has two bolts on either side; one that goes all the way through and has a separate nut, and a shorter one that goes into a welded bung on the hitch itself. I will be outside today working on my junk, including the tow hitch; if you need some pics I will take some for ya. Its really straight forward though.
EDIT:
Just noticed that you didnt say if you were looking at a factory hitch or aftermarket. Mine is factory. I'll get some pics up for ya in a few hours.
Old 06-15-2013, 01:54 PM
foppert's Avatar
Thanks jumper_bob, pictures would be great.
Old 06-15-2013, 03:48 PM
maco35's Avatar
This is the factory hitch that i took off my '87 4runner when i put the tube bumpers on. Name:  P1050487.jpg
Size:  67.3 KB Name:  P1050488.jpg
Size:  79.1 KB Name:  P1050490.jpg
Size:  33.2 KB Name:  P1050491.jpg
Old 06-16-2013, 11:21 AM
foppert's Avatar
Hey maco35, thanks alot man that was really helpful. Are there two mount holes on the brackets that go into the frame? From the pictures i can only see one.
Old 06-16-2013, 04:13 PM
maco35's Avatar
Yes there are two mount holes on each bracket, is just the angle of the pic. you can't see the other two.
06-01-2021 01:51 PM
Poncho0206
07-10-2015 06:21 PM
tpd143
07-07-2015 09:06 AM
HRDC0R19
07-05-2015 06:43 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: first gen 4runner tow hitch
