finally ordered my sas kit from trail gear
Old 04-03-2009, 04:29 PM
desert-rat660's Avatar
finally ordered my sas kit from trail gear, its about time i got the ball rolling on this project
Last edited by waskillywabbit; 04-03-2009 at 05:36 PM. Reason: Title clarity per posted stick
Old 04-03-2009, 05:12 PM
iamsuperbleeder's Avatar
that's a myspace bulletin post if I ever seen one
good job, can't wait fer the pix!!!
Old 04-03-2009, 05:50 PM
Fossilized
Staff
dropzone's Avatar
cool. what axle are you using? rebuild it and put the armor on it now while it is off the truck.
and since you are doing a T-G kit you might find this info helpful...
Front Spring Hanger Placement: (when using longer than stock springs like Trail Gears)
Originally Posted by ScottyC
He can't with the 3" springs. In fact, he needs to mount it 1/4" back of the front crossmember for a decent shackle angle and to have the tie rod and draglink clear each other on compression. Otherwise he'll be having to move the steering box forward.
I have all of these lifts down to a science at this point.
3" springs: 1/4" in back of the frame. Push the frame tube jig all the way forward in the body mount.
4" Springs 1/2" in front. Center the frame tube jib in the body mount
5" springs 3/4" in front. Center the frame tube jib in the body mount
Old 04-03-2009, 06:38 PM
i have the 84 axle with the long truss i got it at pick apart for $300.00. i ordered the 4 inch lift springs. i stripped down the axle and cleaned up all the parts. i started work on cutting the brakets that i wont need off
Old 04-03-2009, 06:41 PM
Tubbyfatty's Avatar
hahaha x2!!!
wheres the pics?
Old 04-03-2009, 06:57 PM
RaginYota's Avatar
I just installed the TG kit on my truck. I was extremely happy with the kit.
What are you doing for the rear? One other thing to remember, you will have to make your a new driveshaft.
There are some pictures here https://www.yotatech.com/forums/f152/rage-s-sas-169024/
If you have questions let me know. The install is still kinda fresh in the brain..lol..
Old 04-03-2009, 07:01 PM
Old 04-03-2009, 07:04 PM
RaginYota's Avatar
having flashbacks...lol
Old 04-03-2009, 07:09 PM
how did your shackle angles turn out, how did u mount the front spring hanger in relation to the front crossmember?
Old 04-03-2009, 07:10 PM
Justinlhc's Avatar
Wow, a local Havasu Toyota guy.
Too bad you're ditching the IFS club. Nice looking truck. I don't think I've seen it around before.
Have you been to that new junkyard in Bullhead? "All good junkyard" I think it's called? I'm wondering what kind of Toyota's they have laying around in there.
Old 04-03-2009, 07:21 PM
i need to change my location. i moved down here to fort mohave, i think that new junkyard is a new pick a part
Old 04-03-2009, 07:24 PM
abecedarian's Avatar
note to site admins- twitter integration?
Old 04-03-2009, 07:29 PM
Justinlhc's Avatar
Ah, I was just working in Mohave Valley today, down Boundary Cone Road. I don't think I was too far away from that yard. I don't see any older Toyota's in the pictures though.
Old 04-03-2009, 08:29 PM
wut?
Old 04-03-2009, 08:30 PM
INFINITY's Avatar
good luck hope it works out with no kinks. hit me up up if you run any trails up around payson
Old 04-03-2009, 08:41 PM
thanks ill post more pics as the project starts coming along, the kit should be here tuesday
Old 04-04-2009, 01:33 PM
934rnr's Avatar
Nice I got my 85 4 runner axle for $200 with the springs.
However urs looks a little less rusty.
Nice job though.
Are you gonna do the creeper ball gussets too?
Old 04-04-2009, 09:43 PM
ya i planned on getting those also
RaginYota's Avatar
I mounted my front hanger flush with the frame. Shackle angle is good, and springs are still settling. I will be getting my front drive shaft this week, so I will have some pictures up by next weekend.
Nice job though.
I bought these also and I installed the steering stops tabs and the lower gussets in. I really saw no need to install the uppers. I am not a hardcore rocks crawler and don't think that I will be bashing my front tires up onto obstacles. But good luck with the install and the hardest part is getting the frame cut for the shackles. Just remember to measure twice and cut once...lol... well maybe just measure about 100 times and cut or weld once...lol.. good luck again!!!!
Laterz
Old 04-04-2009, 10:28 PM
im wondering if im going to have to have the ball ends cut and turned to be able to get my driveshaft angle right, if i cant i think ill just go with a high pinion differential
Quick Reply: finally ordered my sas kit from trail gear
