Finally got time to tear into my newly acquired 94 !
Old 03-17-2013, 06:31 AM
Vmax540's Avatar
https://www.yotatech.com/forums/f116...95-sr5-265913/
Follow up to the 94 that had a "Blown Head Gasket" ! I pulled her into the garage and checked the compression and all are holding and even. The oil is clean as new and the coolant was down maybe 1/3 gallon. Ran until it got to a little less than half on the temp guage, the top Radiator hose got hot but, the bottom hose was stone cold. The heater blew good hot air altough, there seemed to be a mist blowing out the vents for about a mintue or so, then stopped. Note truck set outside not being ran for ~3 months. I could not smell antifreeze in either the mist nor the exhaust. I'm thinking of trying a thermostat from advanced ? What are your thought's ? Thanks !
Old 03-17-2013, 07:49 AM
Vmax540's Avatar
Thermostat with rubber pieces ! Any suggestion on which thermostat and temp from Advanced? (it is Sunday)
Attached Thumbnails Finally got time to tear into my newly acquired 94 !-001.jpg   Finally got time to tear into my newly acquired 94 !-002.jpg   Finally got time to tear into my newly acquired 94 !-003.jpg
Old 03-17-2013, 11:40 AM
Co_94_PU's Avatar
Yeah you don't wanna know what that smoke/mist was, but incase you have a iron stomach heres a clue it was probably alive at one time.
Radiator flow is left to right, it flows out the thermostat thru the radiator and out to the pump, is it past my nap time and I'm confused It should be cold(er) on the engine inlet, just means the radiator is doing it's job.
Not great pictures but I didn't spot anything obviously wrong with the thermostat. Clean it up test in a pan of water and put er back together..
And I haven't read thru the other thread.
Old 03-18-2013, 02:59 AM
Vmax540's Avatar
Mouse..... so, that would explain why it smells like it is an old people car and not antifreeze.... and I was worried about the heater core.... The thermostat had pieces of the inner rubber stuck all through the stem.
Old 03-18-2013, 01:14 PM
Co_94_PU's Avatar
Oh I see it now. Rubber on thethermostat looks ok from here. That stuffs kinda thin like a radiator cap gasket, might wanna give that a quick peek.
06-01-2021 01:51 PM
icentropy
09-16-2020 02:47 PM
jon.r
07-11-2015 03:34 PM
skoti89
07-08-2015 12:05 AM
timmJ
07-07-2015 02:01 PM
Quick Reply: Finally got time to tear into my newly acquired 94 !
