Fan clutch rebuild?
Old 06-01-2007, 03:11 AM
vwfastg60's Avatar
Fan clutch rebuild?
The past 3 runs i have been on my truck has run supper hot! Almost over heated when i was on trail and driving to the trail. Over the winter i replaced waterpump,termistat,radiator,all the hoses.
Heres what makes me think i need a new fan clutch. When the trucks off you can spin it almost freely. when the trucks running cold you can stop it spin it the other way and it will catch up. normal temp its about the same as just started. when the truck is ready to over heat or is starting to you can still stop it spin it and it takes a while to catch up. It used to make noise when the truck as getting warm(cant discribe it but im sure you guys know the sound) and now it doesnt. Is this the issue? could i have another issue?
Can i rebuild this one? I have a friends motor torn apart in the way of my spare parts to see if i even have another to try so if i can rebuild it real quick i will give it a shot.
Im tired of hangin everyone up on a run or even out screwing around. I just got over a starter problem that only wouldnt work at altitude. It seems like this si the same cause i daily drive it and dont have the same issue
Old 06-01-2007, 03:25 AM
Shoretaco's Avatar
You need a new fan clutch if you can spin when hot. Why rebuild it? Replace it or go electric.
Old 06-01-2007, 06:31 AM
snap-on's Avatar
you cannot rebuild a fan clutch, its a sealed special hyrolic thingie-mabob
your looking at $100+ for a new one.
Old 06-01-2007, 06:50 AM
texsurfer's Avatar
mine is going out too. Is it worth it to buy a new one or is going electric worth the hassle? Reason I say hassle is a buddy of mine went electric at less than 100K and replaced the electric fan 3 times in 80K miles before he sold it. Too bad its not rebuildable...
Old 06-01-2007, 06:58 AM
norcalsvx's Avatar
i swapped mine out for the flex a lite with billet spacer its loud but i dont have to deal w/ fan clutches any more
Old 06-01-2007, 07:46 AM
kevinkal's Avatar
Your description of the lack of fan sound when the engine is hot it is damn good evidence of the fan clutch being bad. snap-on is correct.. they cannot be rebuilt. My fan clutch went out at roughly 190K. I just replaced it with a new toyota part. I recall it being a bit pricey, something over $100.
Old 06-01-2007, 06:45 PM
jasonbrink's Avatar
go here: https://www.autopartsworld.com/
Same AISIN clutch as the dealer, much cheaper. add an oil plug gasket & get free shipping. No stake in company, it's just that these people have been great to deal with.
Old 06-01-2007, 11:06 PM
vwfastg60's Avatar
went with an electric pusher fan and adjustable thermistat runs great and frees up some power
Old 06-02-2007, 09:38 PM
vwfastg60's Avatar
ok i like the power still runs hot when in the hills. Im thinking about pulling the t-stat
Old 06-04-2007, 05:34 AM
PirateFins's Avatar
there are plenty of write-ups on the net dealing with how to rebuild them by replacing the silicone fluid in them. The dealer can special order the fluid, it comes in 1 ounce bottles and normally takes 2 to 3 bottles to complete it.
That being said it is probably less stressful to replace the whole unit with a new one, or electric.
Old 06-05-2007, 04:47 PM
vwfastg60's Avatar
the electric one is pissing me off. I think i figured out my timing got bumped some how. I timed it lastnight and it was way off. Maybe that will help.
Old 06-05-2007, 05:10 PM
ShortyzKustomz's Avatar
If not consider upgrading radiator or going with a colder stat, Im running a newer radiator and flex fan in my truck, no problems, even on mountain trails in 4 lo and high rpms sometimes
the1998sr5
15
07-14-2020 08:35 PM
the1998sr5
27
11-17-2015 09:30 AM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
upongame619
08-01-2015 12:12 AM
1996Taco
07-20-2015 12:02 AM
Quick Reply: Fan clutch rebuild?
