extending steering shaft
Old 04-08-2011, 07:22 PM
Nimyad's Avatar
ok so i'm redoing the steering on my SASed 94 pickup. i need to move my box forward and also clock it, but to do so i need to extend the steering shaft. so how should i do this, only idea i've come up with is to cut it, extend it and sleeve it. i'm also trying to run a flat pitman arm and am having trouble placing the box in a good place with my TG mount. so any pics of people that have done that would be great.
Old 04-08-2011, 09:53 PM
skoti89's Avatar
not if this is really what you are talking about, but 4crawler makes steering shaft spacers I think? It's in his body lift section...
Old 04-09-2011, 09:55 PM
Turd Furgeson's Avatar
When I did mine I found some thick walled tubing that fit over the shaft that I cut and welded it over the 2 pieces to extend it.
Old 04-10-2011, 05:54 AM
waskillywabbit's Avatar
Stock driveshaft has two pins in it in the top piece and will telescope if you remove those pins or you can sleeve and extend it. You really want to leave some type of telescoping mechanism in place so the steering shaft extends/contracts with flexing.
4crawler has pics on his site.
:wabbit2:
Jcrawl94
10
10-24-2015 04:34 PM
4x4-runner
08-30-2015 08:55 AM
trailgoat
08-13-2015 05:54 PM
4x4-runner
08-02-2015 09:24 AM
yoterr
07-24-2015 04:29 AM
Quick Reply: extending steering shaft
