Exaust sound
Exaust sound
Recently, I installed an LC Engineering Header and magnaflow Hi-Flow cat on my 22RE 94 pickup. Im satesfied with the fit and performance, the sound is less that attractive. Im running a cherry bomb and 2 inch piping back from the cat an a 90 degree near the end of the line. the sound is raspy, and frankly, it sounds like a civic with a coffee can muffler. is there any kind of muffler or setup that I can instal that will make it sound a little more throaty?
x2. Other then the drone in my cab, I like my $30 Thrush turbo and 2.25 piping back from a downey header with a magnaflow standard non-hi-flo cat. I did however have to add a resonator tip to keep the sound at full throttle from being too raspy.
But carb'd trucks to me sound different then the EFI trucks so it might not sound the same on an RE motor.
