engine wont rev past 2000rpm?
Old 08-04-2008, 07:15 PM
carova_kevin's Avatar
What could cause this? idles good and revs clean until 2000rpm, then acts like it has a rev limiter or somthing keeping it from reving higher. What yall think? thanks
Old 08-04-2008, 07:22 PM
Jay351's Avatar
22r or 22re?
Check the catalytic converter, might be clogged.
Old 08-04-2008, 07:48 PM
Pedram88's Avatar
Sounds like timing issue. Check your spark plugs. Rotor, stuff like that.
Old 08-04-2008, 07:52 PM
abecedarian's Avatar
valve adjustments, cam timing, ignition timing, ignitor (or related circuits)...
vacuum leaks, fuel filter...
spark plug wires, distributor cap or rotor arcing out
Old 08-04-2008, 07:56 PM
iamsuperbleeder's Avatar
Incorrectly installed TPS as well... seen it happen twice on the 22re and had the same issue you describe. Have you had it off recently?
Old 08-05-2008, 04:48 AM
gte718p's Avatar
Take off the cummins rev limiter?
Old 08-05-2008, 05:49 AM
InternetRoadkill's Avatar
AFM is sticking.
Old 08-05-2008, 12:08 PM
Team420's Avatar
Fuel filter.....
Old 08-05-2008, 12:16 PM
1stoyota's Avatar
RPM Fuel shut off
There is a test procedure in the FSM linked in this forum for a RPM Fuel shut off. It indicates that after unplugging the TPS and jumpering the bottom two wires, the fuel shut-off should activate at about 2130RPM and drop down to 1900 repeatedly. If that is occuring, it could very likely point to a fault in the TPS.
Just a thought, but I'm new to these trucks....
Old 08-05-2008, 12:24 PM
Team420's Avatar
^^ Hmmm... never would have thought of that^^
Old 08-05-2008, 04:21 PM
Originally Posted by InternetRoadkill
AFM is sticking.
Most of the time when that happends, the engine does more of a random spit and sputter and can not rev higher because it is lacking the fuel to do so...
The "rev limiter" remark, as in a rythmic up and down rev with the skinny pedal held down, leads me to believe a timing issue is to blame, more than likely caused incorrect information from a sensor that can alter the ingnition timing...
leading me directly to the TPS...
just my .02
Old 08-05-2008, 04:48 PM
I did take the tps off recently. will get one and switch it out next. Fuel filter isn't that old. Thanks again for all the input!
Old 08-05-2008, 04:54 PM
try removing the one you have and putting it on again. it may be working fine, it may just be installed incorrectly
Old 08-05-2008, 08:35 PM
just a 22re's Avatar
make sure its right to spec with the way it sits on there to just a though
Old 08-10-2008, 05:13 PM
Ok. swaped out the tps because the one that came off drags a little if i twist the spring. Still has the rev problem.
But just for kicks i unpluged the connector and it reved the way it was suposed to. Could it be installed wrong still? it seemed pretty self explanitory on how it fits on, i lined up the small groves on the sensor to the throttle gate piece....idk. Ill try the timing next.
Old 08-10-2008, 05:19 PM
when I installed the tps on my 88, I noticed that the throttle shaft has tabs that push on the tabs in the tps, so when installing it, I rotated the tps in the direction of throttle rotation then slid it on the throttle body. then I rotated it the other way until when I let it go, the spring in it caused the tps to rotate on it's own, meaning it was pushing against the throttle tabs.
then I put the screws in it and snugged them down and connected the plug. at this point, I started the engine and bumped the tps sensor until the idle speed dropped. I bumped it both ways very slightly until I got it right at the point the speed dropped and tightened the screws.
following that, I put a jumper in the diagnostic TE1 and E1 terminals to make sure the ECU was getting the IDL signal (the rpm's drop even more) and checked the timing.
Old 08-10-2008, 05:30 PM
that's the easiest way to do it; as close as you can get it without a multimeter
Old 08-12-2008, 06:02 PM
thanks for the help. ill mess with it again this week sometime.
Colington
03-08-2020 09:51 AM
Alex Bessinger
08-31-2015 09:17 AM
Poncho0206
07-10-2015 06:21 PM
colinmil
07-06-2015 04:03 PM
wilbertd
07-06-2015 07:39 AM
Quick Reply: engine wont rev past 2000rpm?
